Do the self check if it comes on for a moment and then the power light goes off.
On the front of the set hold both the MENU and INPUT(also called DEVICE) together for at least five seconds and then release both buttons.
The power light will blink an error code--for example 2 blinks a pause and 2 blinks--it will repeat it several times. 2,2 is the most common error code for this set.
Let me know what you find and I will tell you what it means--it is designed to give a quick idea of what is wrong with the set.
if this helped you rate this solution as I do this here for free.
SD TECH
it means one of the two fuses that are soldered in for the convergence circuit are blown.
This model uses two of the STK-392-570 CHIPS---blown fuse means one or both are bad.
What needs to be done is replace both chips and fuses and adjust set.
If it is of interest to you I have start to finish instructions for this repair--done hundreds of them.
shops will get 300 or more for this but actual parts cost from EBAY is under 30 dollars total.
Let me know if you are interested in the instructions.
SD TECH
Could I get those instructions
2,2 is flashing that we got. What does this mean?
