Indesit 24 in. DI67 Free-standing Dishwasher Logo
Posted on Dec 12, 2009
The wash light Indesit DI 67 dish washer is flashhing ?
The wash light on my Indesit DI 67 dish washer is flashing and it's not working help please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
764
Points
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
1helpful
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
1helpful
Indesit 1200 series wont work.
F03 indicates that the wash thermistor is open or short circuit, the thermistor is part of the heater element. you need to test the heater and thermistor, and possibly replace.
Indesit recommend that you call an engineer, but it can be done by some one who is competent enough.
Unplug before you do anything to it.
Plz leave feedback.
Thanks
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
8helpful
2answers
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
2answers
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Indesit Di 67
Tilt your washer forwards. Water will leak from the front but once this has cleared your dishwasher should be ok again. I paid an engineer to come and tell me this. If your dishwasher is not completely level this can sometimes happen. Hope this helps.
2helpful
DI 67 S fault
Try to tilt your dishwasher forwards. Be aware that water will leak out of the front. Once this is clear it should work. I paid an engineer to come and tell me this. If your machine is not completely level it causes it to over fill and after a time will not work. Good Luck
2answers
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Top Indesit Dishwashers Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
