Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
Posted on Jan 21, 2008
Lexicom Lambda is not working! New user
I have an Acer Aspire T180-UA381B AMD with 4GHz ram and a
Ge Force 7200 video card, I switched the OS form Vista to XP PRO. I have the following sound,video and game controller drives installed:
Lambda In/Out 1.0.2
Lambda MIDI Deice 1.0.6
Realtek High Definition Audio 5.10.0.5532
Unimodem Half-Duplex Audio Device 5.1.2535.0
When I start Cubase I get the message ASIO driver Lambda could not start. I can not record. Can you help a brother out?
  • 1saxman Jan 21, 2008
    Thanks but it did not help.
marcial nasi
Level 1:
  • Contributor 49 Answers
  • Posted on Jan 21, 2008
marcial  nasi
Contributor
Level 1:
Answers
49
Questions
0
Helped
12378
Points
86
Right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
1 Related Answer
A
Anonymous
  • Posted on Apr 11, 2008
SOURCE: My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
WHAT TYPE OF BATTERY
They are all the same size at least the last 200 i can remember were
SONY CR2032 Equivalent CMOS battery
Add another video card to my Acer T108-UA381B to have two displays but system only see new card. Does not recognize the bus video
most desktops disable on board GPU in favor of the better add-on card. Your best bet is get an add on card with multiple outputs and hook all your monitors to that card. Using 2 different cards is a pain in the aft.
I wanted to get my acer aspire T180-UA381B upgraded, and I know very little about computers, how much and what kind of ram should i put in to make it run fast
Based on your memory specs below the maximum RAM that you can install in your computer is 1GB
DDR2 SDRAM and you can get 1GB RAM for like $15 -$ 20. 1 GB DDR2 SDRAM is what you need to buy.
Your Memory Specs:
Installed Cache Memory: 256.0 KB
[close] Installed RAM: 512.0 MB RAM, or Random Access Memory, is the place in a computerwhere the operating system, application programs and data in current use arekept so that they can be quickly reached by the computer's processor. Theamount of RAM you have affects how quickly you will experience your computerworking.
[close] Installed Video Memory: 512.0 MB
[close] Max Supported RAM: 1.0 GB
[close] Number of Memory Slots: 4 x 240 Pin DIMMs
[close] RAM Technology: DDR2 SDRAM
Acer Aspire T 180 stops with Acer Logo
What you were trying to do tried to remove the RAM and boot your pc. Buddy once you remove your RAM you are going to get long beeps as it tells there is no RAM on mother board and it won't boot. Just install back all the things and let me know how many beeps you are getting and what type short and long.
2answers
How do i connect my acer pc to my 42 in jvc hdtv
You have to purchase a good quality 3DFX video card to ba able to hook into TV
2helpful
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
4answers
Loss of graphics - Acer Aspire 3600
Hey there besafe, the problem of your video driver is easily solved. If your computer is new, then you may have the driver CD for the motherboard installation. Alternately you can download the driver from the motherboard manufacturers website, assuming the video is onboard. If it is an installed video card, and you are without the driver disk, you can usually get the specific driver from the manufacturers of the video card website, specific to your OS. These drivers are easy to install therefore the best first step. If that does not work, then look at the hardware. If you have a video card installed, reboot your computer and enable the onboard video. If this works, then your video card may need replacing, preferrably with something having a higher built in memory and more suited to your usage. Hope it helps. Good Luck!
Top Lexicon Computers & Internet Experts
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
