20 Most Recent
Lexicon Omega Pro Studio External Sound System Questions & Answers
Device is unrecognised always day per day
I've been struggling with this issue for about a week. My unit was locking up increasingly more often.
Two things I've noticed about my Lexicon interface:
1. Seems to be excessively hot.
2. The unit is not vented.
Yesterday, after reading a comment about the solder possibly being the problem, losing conductivity as the units warms up. I decided to run my Lexicon with the plastic case removed.
Since removing the the case, i have only had one instance where the sound stopped working, which i believe was a problem with Cubase in that instance.
I'm not sure if removing the case to keep the unit cooler is the solution. I may have improved a connection somewhere in the process of opening up the unit.
I can say that I went from getting a "new hardware found" message every two minutes to having virtually no problems since removing the case.
My next step will be to drill about 50 holes in the case to vent it before attempting to use the case again.
Best of luck to ya!!!
Lexicon driver
There is a major design flaw with the Omega. The ribbon cable touches one of the power tabs that tends to get very hot. this causes the ribbon cable to melt and damages it.
If you open up the case you will se it straight away.
If it is under warranty take it in to be repaired. It is a simple repair and should cost yo nothing.
Otherwise buy a new ribbon cable (I'm guessing most computer shops would sell them). Rplace the old cable with the new one then insulate the new ribbon cable (with electrical tape or something stronger) where it touches the power tab.
I also drilled a few holes in the top and sides of the case (do this carefully as the case is weak).
Be aware tho that drilling holes or altering the case will void your warranty.
My sound card is crashed.help!!
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
I have a lexicon omaga drive but when i hook it up...
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\ksproxy.ax, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
C:\\WINDOWS\System32\drivers\portcls.sys,
C:\\WINDOWS\System32\drivers\stream.sys,
C:\\WINDOWS\System32\drivers\USBAUDIO.sys,
C:\\WINDOWS\System32\ksproxy.ax,
C:\\WINDOWS\System32\ksuser.dll,
C:\\WINDOWS\System32\wdmaud.drv,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
Noise in the lexicon omega
The solution is NOT to use this piece of **** indexing site that just loads questions from other sites and makes money via google ads
Lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
One day I turned it on, loaded the software. Error message...
This product is JUNK. An associate of mine advised me to purchase this piece. It worked less than six months. Now the unit is fourteen months old. Lexicon said they'd be happy to have me return it along with a money order, certified check or credit card number because the charge would be $75.00 flat to either repair mine and send it back to me, or replace the entire unit.
The associate who advised me to purchase this piece of gear works on microcircuits each day in his line of work. He uses microscopes to examine his work. One day when his Omega quit working, he opened it up on his bench where he identified numerous cold-solder joints. He repaired them and the unit worked for about three months before becoming unstable. He opened it up a second time and noticed all the jacks were starting to get loose.
At that point, be became aware of the $75.00 option with Lexicon. Instead, he deposited his Omega into the dumpster behind his place of employment. Today, his unit is a part of the landfill in Dallas, Texas.
LEXICON ABSOLUTELY KNOWS ABOUT THE PROBLEMS WITH THE OMEGA. LEXICON SHOULD REPLACE THE UNITS AT NO COST; CONSUMER PAYS SHIPPING IS FINE WITH ME. TWENTY YEARS AGO, LEXICON BUILT RUGGED AND DEPENDABLE GEAR. IT IS TOO BAD THEIR FINE NAME IS ON SUCH A PIECE OF ****. I'M AFRAID I'M DONE WITH LEXICON, FOREVER. IT WOULD BE TOO DIFFICULT TO CONSIDER PURCHASE OF ANYTHING WITH THE NAME ON IT.
Interface
download updated drivers from the manufacturer's website
especially if you are using XP / Vista
Won't play through Computer Speakers
Hi, go to start, control panel, Sounds and audio devices. You will need to set the audio system up here. Select the connection you have to the system, that should cure your problem.
Regards mistyman
Haven't used my lexicon omega in years,cant find the serial number.is there away to get it from Lexicon? Or any other place?
tell why you need the SN, it is out of warranty or the software app for it asks for SN?????no PC told nor OS told. no context told (why do you ask, MISSING)Lexicon produced an expensive PCI card/breakout box combo dubbed the Studio back in 1998 (reviewed SOS July 1998You don't even need to install drivers with Mac OS X: the Omega integrates right away with Core Audio (as long as you're using Mac OS 10.2.8 or above).lost the 1998 software bundle CD???? OOBE lost now?it runs w2k and XPsupport is here.https://lexiconpro.com/en-USthe review is here.https://www.soundonsound.com/reviews/lexicon-omegaconnect power and usb to the below jack.then in windows (is it windows. gee)load the CD bundle software.and go to device manager. (XP?)then there, find the LEX line. off USB.then at the LEX entry right click it and pick Properties and then,click tab details and all Idsthere to find serial if lucky.
6/22/2022 1:10:22 PM •
Lexicon...
Answered
on Jun 22, 2022
Hi. Is the Laser on the Lexicon RT-10 the same as the Lexicon RT-20 (Universal disc Player)
googling I see nothing,. 2003 21 years old it is.not told, I only have questions and do you really understand the limitations of licenses for SACD and ADVD.what is end goal fix it and uses it or sell it after buying one dead.??????????? goals mattergoal #2, do you need this licenses for SACD and ADVD.??????? do you have 2009 dead media, to play?dead as in production ended SACD.that limit locks all this down , fully.The maker does not support it;.the maker has no service manual.s and the users manual forbids, DISASSEMBLY (sure for SACD/ADVD) there maker has no spare parts leaving only used ones on ebay or the like kinds (Parts pullers)a used working drive sells for $300, 1/10th of new or less sold used, now.There are other SONY decks for $400 sold.now let me say how, licenses for SACD and ADVD. works.as see on the PS3 play station it is 100% hard not locked down.the parts inside the drive all cross check each other and are married and most can not be willlynilly swapped.The owners of SACD make that happen. in the license.the parts inside the driver can be ID SN locked and even the whole drive locked to the main base chip or firmware.lacking a service manual means all this is a pathway to doom, (huge cost buying worthless parts)why go here.better if not using SACD/ADVD (not told)vast alternates exist and far better and for sure full support and a real future
6/14/2022 10:27:46 PM •
Lexicon...
Answered
on Jun 14, 2022
