Mitsubishi WS-65411 65" Rear Projection Television Logo
Posted on Dec 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Mitsubishi medallion 65 and it keeps turning off,
I have a Mitsubishi medallion 65'' big screen, model ws65411. It turns off by itself. I can turn it back on after a few seconds and it might stay on a few hours or a few minutes. What's the problem?
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Dec 08, 2009
Anonymous
Master
Level 3:
Answers
927
Questions
Helped
302480
Points
1655
Dear Sir,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. I hope this helped.
Good Luck, big IRISH.
  • 1 more comment
  • Anonymous Oct 01, 2011
    redid diagnostic. got new code 2 blinks pause 3 blinks repeats.
  • Anonymous Nov 07, 2011
    I got 2-2 problem code, but I checked the 2 fuses are ok, less 0.1 OM.This problem was happened suddenly when I watched the NFL football today. Please what solution to solve this problem. [email protected]
  • Sandy Rodgers
    Sandy Rodgers Nov 18, 2014
    I got a 2-3 on the code? what do I do to fix the problem [email protected]
1helpful
Mitsubishi WS65411
It will be best to contact the authorized service center for Mitsubishi; in this case. Gopakumar Gopalan Google
2answers
Have a 65'' mitsubishi model #WS65411. Screen goes from a good coloered picture to black screen & keeps flashing back&forth between the two.
Ok so you have a projector pointing at a 65'' Screen?
Where is the projector receiving input from ?
Did you hust get this projector ?
please add more details so that we may be of quick and thorough assistance.
1helpful
I have a 65" Mitsubishi
Im, not sure what it is that you are wanting to know about this Model# WS65411,But this TV has 3 Tubes Red,Green,Blue their is No Bulbs Just 3 Picture Tubes.
Encompass Parts Distribution List Parts and PN# for this Model 1-800-638-3328
Visit this website for Part Numbers for R/G/B Tubes.
1helpful
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
8helpful
2answers
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
1helpful
2answers
My 65 in mitsubishi medallion hdtv 1080 wont turn on green light flashes but will not turn off?
Fisrt try resoldering your Boards then Ck pico fuses they are green or yellow look like resistors but are fuses 5amps or 6amps also you may need to replace Both of your STK ICs they are Big Black ICs will have Part number on them example STK392-570 Call Mats For these 1-800-628-1118 Go by number on your STKs
2helpful
2answers
Mitsubishi Medallion Big Screen Projection TV
I had the same problem and ended up being a board and cost me about 400 bucks to fix it.
8helpful
4answers
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
