Usb connection not workin. Doesnt come up with the connecto to pc prompt. 2 computers tested 4 cables all of which work with other devices, Have reset the archos 5 ...
Help ....................
Unpack your new scanner and set it up. Follow package directions and setup instructions to assemble any parts that need assembly.
Plug in your scanner and power it up.
Insert the setup CD in your CD-ROM or DVD drive. It should autotomatically run. If it doesn't, click on "My Computer" and then on the CD or DVD drive to open the CD. Look for a Setup.exe file. Double-click on it to launch the setup disk.
Follow the onscreen prompts to complete the end-user agreement and install the necessary drivers and software to run your new scanner.
When prompted, connect the USB cable to the scanner, then plug the other end into the USB port on your desktop PC.
Windows will recognize that a new device is available on your computer, and find the necessary software and drivers to install it.
Restart your PC if prompted to do so.
Troubleshooting
Check all cable connections to be sure that they are secure.
Disconnect the USB cable from the desktop and the scanner.
Turn off your computer and let it cool down for 10 minutes.
Turn the computer on, then turn the scanner on. Reconnect the USB cable to the scanner. Try connecting the other end of the USB cable to a different port on your computer.
If none of these suggestions solve your problem, uninstall the scanner and start over.
