Ovens Logo
Anonymous Posted on Dec 02, 2009
Delonghi ESM465ST Oven Noisy Fan
Hi there
I've got a Delonghi ESM465ST oven and after it's been on a while, the fan sounds like changes gear for want of a better word and makes a really loud whirring noise like an aeroplane. Is this a problem with the cooling fan?
Thanks
Barry Coates
Level 3:
  • DeLonghi Master 3,463 Answers
  • Posted on Dec 02, 2009
Barry Coates
DeLonghi Master
Level 3:
Answers
3463
Questions
Helped
1407025
Points
12766
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Testimonial: "Thank you for that. It's noisy even when the fan inside the oven isn't running (ie, just on convection) so guess that means it's the external fan?"
  • Barry Coates
    Barry Coates Dec 02, 2009
    Yes, I would concur that it is going to be the external cooling fan
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 14, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4836
Points
0
I managed to fix it as the horrendous noise like a plane taking off was due to the vibration of the spindle of the "cooling" fan (the long cylinder with blades) rattling in the metal part of the rubber bung in which it sits at the opposite end to the motor end (that spindle is fixed). This is not the fan at the rear of the oven you see when you open oven door which circulates hot air when fan assisted oven is on.
Disconnect from the mains first and then take the top outer casing off my De Longhi ESM 465ST by removing the 6 screws and lift off cover with and the fan was easily accessible. Simply remove the rubber bung at end of spindle and add 1 drop of oil and put it back. It worked a treat and took me all of 15 minutes and saved me buying a new oven.
  • Anonymous Aug 17, 2013
    Yes we had the same problem and followed your advice, but used WD 40 in the bung and it fixed the problem.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4836
Points
I had this on my cooker a few months ago. I took the hob off, (quite time consuming, but not difficult) and found the long fan. Atfer needlessly removing the fan, I found one of the spindals/axles had come out and the fan was unsupported. I just puched it back in and it's been fine since.
Hope this helps.
1helpful
Over heating fan oven
it sounds like you tod is faulty its the little stat at the back on the right hand side two wires going to it ok make sure to swicth oven off
tip
Delonghi Oven not heating? How to replace a Delonghi fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
on Jan 30, 2014 • DeLonghi Ovens
2answers
I have a DeLonghi Oven, Model No. DMFPS60 (F6ET), which is very noisy, this occurs intermittently and it continues being noisy in all the Functions Selected, i.e. even when it is in the "Oven...
I have a simlar oven, with the same annoying problem.
Ifound out that the problem is caused by the top blower-fan (the cylindrical fan) that is moving from time to time to the right or left along its axis.
Having this very same problem I would like to know if anyone can help me on buying the appropriate fan, or, atleast help me in giving its part no.
Thanks
Naftali H.
P.S.
I tried to fix my noisy fan by pressing it here and there (sqweezing/expanding it a little at the edges of the exis), with no real success.
6helpful
Delonghi esf461st built in fan oven. No operating instructions. What does the middle knob do? It has 4 settings, one for the light one for the grill and 2 more, which must relate to the oven function. One...
The setting with the fan is fan only function.
The setting with the fan and circle is for fan and element for heating the oven.
Please rate my solution.
Thankyou.
4helpful
Oven blown up??? Is it a simple fuse or is it a big job???
sound like fuction switch has blown apart quite common and the noise is prob coming from cooling fan and not the main one inside.
Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
6helpful
2answers
Delonghi esf461st oven not heating up
grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
Sep 06, 2008 • Ovens
Top DeLonghi Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
