LeapFrog Tag Reading System w/ Bundle Logo
Anonymous Posted on Nov 30, 2009
After trying for 2 days over many hours I still cannot get the reader to connect with the TAG download site - The error message says that the server is busy and to try again later - There is also a problem with finding a driver for the TAG pen - Is the tag reader faulty I have 3 new books to download to the reader but cannot do this as I cannot contact the website
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2442
Points
The problem was the firewall settings - Leapfrog provide a fix for this on http://www.leapfrog.com/support
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
2answers
Tag will not update
try downloading it on another system and transfer it to yours.
4helpful
Download error, http response: 404 not found i can no longer download videos from youtube.
This isn't an error at your end, what this error message means is that the server hosting the files for downloading has changed the location of the file you are trying to download. So the URl address of the file has changes and when you try to download the file with the old address it throws very popular 404 error.
So don't worry about it, try after 1-2 days and you will able to download.
Thanks !!
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
(Make sure your toy is powered on.)
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
At home, have been unable to connect to Yahoo email. Here, emails sent to Yahoo email are getting a cannot send error. ----- Transcript of session follows ----- ... Deferred Warning: message still...
Please make sure that you've entered your Yahoo! Mail address as the "From" address in your email client. You won't be able to send mail if you've entered another address.
If you have the Norton AntiVirus email feature enabled, you might have to do additional configuration to use Outlook or Outlook Express. For more information, please visit the Symantec web site.
If you've tried the above steps and continue to have problems, your ISP might not allow its users to send messages with other companies' SMTP outgoing mail servers.
If you're unable to send email, try using port 587 when sending via Yahoo!'s SMTP server. Here's how to make this change in Outlook:
1.From the "Tools" menu, select "Accounts."
2.Select your Yahoo! POP account and click the "Properties" button.
3.Click the "Advanced" tab.
4.Next to "Outgoing server (SMTP"), change port 25 to 587.
5.Click "Apply." Then click "OK" and "Close." Source(s): http://help.yahoo.com/l/us/yahoo/mail/ya…
Dec 03, 2009 • Yahoo Mail
Cant install adobe reader on my pc as error
You can read adobe reader new version and install that...If your OS is XP, it will support all adobe readeer....I think your download is not perfect.please try the above way...Hope you will succeed....
I am useing Microsoft Outlook and keep getting a message when I try to send emails, Your outgoing smtp email server has reported an internal error if you contiune to receive this message contact your...
The problem is clearly indicated on the error code.
"the server responded 521 user is over the limit for messages to be sent in a single day."
Have you been sending a lot of messages using that account? From yahoo:
The limit for messages for yahoo is 100 per hour, max 500 per day.
If you believe that you are the one not doing this, you can either report this to yahoo or checked your Yahoo! account immediately. Change the security settings and most specially the passwords. It could be that your account is used as a spam bot.
Sep 22, 2009 • Yahoo Mail
1helpful
2answers
I can not connect to my friend when trying to play online. I tried to send him an invite, and he recieves an error. I accept his invite and i get a message downloading game settings and nothing happens. I...
Welcome to the servers at call of duty :)
I've got a ps3 and call of duty 4+5, half the fun of the game is playing with a mate and I've had exactly the same problem as you. It just seems to be about trial and error sometimes, have tried connecting like you for over an hour before and then on other days it just connects wth my mate straight away.
Sometimes it helps to join a game(so you can see and hear other players) then invite your mate, if he/she to reply to your invite is quick sometimes you can get in that way.
The only other bit of advice is to try different times of the day as the load on the servers does change throughout the day, apart from that it really is an issue with activision and for me the playstation network
hope it gets better for you
tim
2helpful
4answers
Computer will not download the connect cd
Question   My computer meets all the minimum system requirements but when I try to download the LeapFrog Connect Application, I receive the error message "Your computer must meet minimum required System Configuration" trnsp.gif   Answer   Please make sure your monitor resolution is set at 1024 X 768 pixels or higher and then try to download the application again.
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
