If you are trying to unplug the harness from the ice maker housing, take a small screwdriver and press in on the tab that locks the harness into the ice maker. If you are trying to remove the harness from the back or side wall, there is a small tab on the side of the plug that needs to be pulled out to unlock it.
Possibly a bad valve but more likely not enough water coming to the unit,follow the water line from the back of the unit to where it hooks to the pipes there is usually a little saddle valve there,try closing it all the way and then open it back up check the water through the door and see if the pressure doesn't improve.
You can also remove the Ice maker clear out the fill tube and sit a cup under the end of it for a day or two if you get water in the cup and Ice in the tube you probably have a solenoid valve that isn't closing completely.
The problem is most likely the water control valve on rear of refrigerator.There are two sides on what is called a dual water control valve. If I had your model number I could tell you the part number. The second possibility is the thermostat inside the ice maker is defective. The way to test is to fill ice maker with tap water let freeze and if it dumps and does not refill then the water valve must be replaced. Let me know and please rate my solution, Thanks, Sea Breeze
I would first try turning the temperature down on your freezer before considering buying any parts. Your ice is freezing before it is reaching the position to dump in the bin. Also, if you have any items packed around the area where you ice maker is, try to free up a little space around it. If that does not work I would call the manufacturer, they will be more than happy to walk you through any problems you may be having with there products.
If The ice maker has completely stopped producing ice
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
