Hi, My Nokia CK-7W car kit won't remained switched off after switching the ignition of the car off.
I tried resetting by disconnecting the car battery, but as soon as I reconnect the +ve the car kit restarts and remains on!
Any ideas?
Many thanks,
Chris
Main control box could be anywhere behind the dash, try under the glovebox or under the radio. If you have a mute harness to make the sound come through the speakers, this could also be the problem as is sound like you have 12v constantly on the blue wire.
Sometimes the relays inside the mute harness stick due to wear and tear, you may be best to get an engineer too have a look at this as they will probably find the junction box quickly and have spare parts, try Nokia support web site for accredited engineers locations, You can see myself in North Wales.
Thanks Dan,
An approved Nokia Installer put it in for me prob 4 years ago. This is the first issue I have had in this time. It has worked really well for numerous years with 3 different phones (as my upgrades have come in).
I don't think that the button is stuck in since it still works correctly (I.e. the hold for 2 seconds initiates the voice dial, the hold for 10 seconds initiates a clear memory etc).
Where would the main control box be?
Many thanks,
Chris
Thanks Dan, I will have a look when I'm next at the car. When a call comes through, the Radio does automatically shut off and the phone ring comes through the speakers.
Do you have any idea why this might start to happen now. I haven't had any work done to the car, nor changed my phone etc? Thanks, Chris
You have done the corrct thing of removing power as these units lock up sometimes, if possible you will need to locate the main control box and check to see if the blue wire is connected to and ignition source, it sound like this is wired to be live all the time. Also have a look at the Nokia button, sometimes these stick in. Is this a problem that has just occured of have you installed it recently? Dan
