Hi.
The Oven getting lock after self cleaning is not uncommon.
That is caused by the high temperature reached on self cleaning, that can jam the control board or damage the door lock or the temperature probe.
Try first tripping circuit breaker or disconnecting power cord for five minutes.
After restarting try the oven.
If the oven still does not work, then hold down the cancel button for ten seconds.
If still no luck, then the oven is faulty in consequence of the extreme temperature reached in self cleaning.
If the Oven has regular display, then faulty part is usually the temperature probe.
If oven has no display, then the control board may had been damaged.
I can understand what problems a faulty oven can be in this moment.
Try first the reset, if that does not work, ring the number listed at the end of the owners manual to see if today any technician is available.
A local technician could easily put back the oven to work, replacing the probe, the point is that it will be difficult to find a technician right now.
Let me know if the reset works.
Regards.
Note the comments about using a commercial oven cleaner
("Easy Off" is one oven cleaning product that works well)
One product I find that works well on all oven surfaces is Mr Muscle kitchen cleaner. I have a real hard time finding it in the USA stores. Product image and description Link below:
http://www.mrmuscleonline.co.uk/kitchen
Thanks for choosing FixYa,
Kelly
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
