My cdx sounds really crackley and muffled I have replaced phono lead I think it is a sound card connection problem when I move the phono leads at the rear of the unit the sound problem sometimes gets better but it very temprementel please can you advise thank you Tony
Did this ever get solved ? if so how ?
just a quick update .
i took my cdx to peices and used a pic chip programer to copy , blank then rewrite the onboard chip this seems to have fixed the problem it may have been a build up of static or something and even just taking the chip out and repalcing it may may work also i slightly bent back the capacitors that were touching one of the heatsinks . all i know is this has worked ever since . sorry this is a bit vague but when u open the cdx up you can see the boards with the removable chips in them just remove and replace to see if this helps
if not you need to purchace a willem programer or something similar ..
im not sure if im supposed to post a link here but this is just to show you what a willem programer is http://cgi.ebay.co.uk/Advanced-Willem-EP...
hi i tried this firmware and it failed now my cdx just has red lights how do i fix this do you have another firmware [email protected] is my email please help
Hello
faced the same pb only with MP3s audio tunes burnt on cds (crackles..pops ect ) - no prob with normal cds
SOURCE: Numark CD mix 2
Hi aondj
I would remove the back panel, and get access to the soldering of the connectors that are giving you trouble. resolder them, and see how you go. Get back to me here if this does not cure it and we shall get into it further
regards
Graeme
SOURCE: numark cdx
i have all the same problems as the person above. and it makes me want to throw them in the garbage.
