The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
The AV1 and AV2 switch position can be used to program a
VCR, DVD, STEREO, 2nd DIRECTV Receiver or 2nd TV with
the following instructions.
1. Turn on the component (e.g. DVD Player) you wish to
program.
3. Move the slide switch under the AV1 (or AV2) icon.
4. Press and hold the MUTE and SELECT keys at the same
time until the green light under AV1 (or AV2) flashes
twice and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of component being programmed. If performed
correctly the green light under TV will flash twice.
6. Aim the remote at your component and press the power
key once. The component should turn off. If it does not
turn off, repeat steps 3 and 4 trying each code for your
brand until you find the correct code.
7. Repeat steps 1 through 6 to program a new component
under AV2 (or AV1).
ok
