Your GPS receive its date and time from satellites. Take the unit outside and acquire a satellite fix in order to update your time and date. You can set the time zone and time display (12hr, 24hr, UTC) under the unit setting.
To change the date on a 2006 Buick Rainier, you will need to follow these steps:
Press the "Time" button on the radio to enter the clock setting mode.
Use the "Hour" and "Minute" buttons to set the current time.
Press the "Month" button to enter the calendar setting mode.
Use the "Month," "Day," and "Year" buttons to set the current date.
Press the "Time" button again to exit the clock setting mode and save the new date and time.
If you are unable to change the date using these steps, it is possible that your vehicle may have a different system for setting the clock. In that case, you may need to consult the owner's manual or contact a Buick dealer for further assistance.
December 22, 2012, the first day of the new piktun of the Mayan Calendar. The Mayan Long-Count Calendar ended for the first time on December 21, 2012. Many fans view this as an error and think the date should have been December 21, 2012 which was thought by some to predict the end of the world .
I called AT&T about this same problem..........the CLAIM they know and are working on the problem.......meantime, I cannot get CONFIRMATION with correct date of my texts, yet they go thru
Nuvi 200 - trying to reset the date using the method suggested by Kevin A (and in a cellar) and after two hours the Nuvi was still "locating satellites". Am I doing something wrong?!
My main problem, however, is that having loaded a copy of the latest European maps onto the card used in the device, when going through the "where to" routine I am asked to enter State/Province. Living in the UK this is a little difficult as there is no answer I can give that the unit will recognise! Any ideas?
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time. But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
If you are turning the GPS OFF by master switch this information will be lost always.
If just using the front buttons then it will remain as you set it There is no spearate power memory for when the unit ges flat from main battery or having a separate memory battery
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
