Audacity is an all-in-one multitrack recording program. You can follow below steps to do that.
The interface of it is simple, which is very suitable for beginners to use. Its ability to record multitrack sounds excellently will satisfy you to the most. The following steps show you what you need to do.
1. First, you need to make sure you have set up the USB sound card on your computer properly and you can access stereo mix in the recording properties.
2. After that, you need to prepare the multiple audios that you want to create multitrack recording.
3. Then, you can fire up the Audacity application on your computer and then click on "Edit> Preferences> Devices" tab successively.
4. Select "Stereo Mix" as the device under "Recording" menu and then select the recording quality according to your demands.
5. Finally, you can hit on the "OK" button to begin to record the multitrack audio file. Remember to play the sound tracks on your computer at the same time to allow the software to record them simultaneously.
This USB sound recorder software is quite easy for you to handle. You can also use it to mix multiple tracks directly when necessary.
For more details, check:
How to Record Multitrack with USB Sound Card using Audacity
