Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Go to your bluetooth settings and make your phone discoverable, normally you need to hold the power button down on your headset until it flashes red and blue, then you will need to select the headset on your phone, the default code is usually 0000
For Cellular Innovations Mini Blue HFBLU-AX1C. To Pair with Your Phone....
1. Turn OFF Bluetooth Headset 2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode) 3. Search bluetooth device through your mobile phone. 4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
