20 Most Recent
Cellular Innovations HFBLU-AX1 Bluetooth Phone Questions & Answers
Will not pair with my I phone
I phone will not support file transfer thru BT....it will only support BT headset and nothing else can be connected thru BT
2/3/2015 3:13:45 PM •
Cellular...
Answered
on Feb 03, 2015
Pin for head set
ITS either 0000(gen default IN MOST OF BT head set like Nokia i ball etc)) OR COULD BE 1234
If not contact manufacturer user manual
2/3/2015 3:11:42 PM •
Cellular...
Answered
on Feb 03, 2015
BT pairing code
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2.
With Headset within 1 Ft of your phone, hold down power key for about 8
seconds until indicator light blinks in red and blue color quickly (in
pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
6/13/2011 3:15:53 PM •
Cellular...
Answered
on Jun 13, 2011
I need a manual
try reading this article. this is not a manual but you can get a help from this i hope.
click
here if it helps please leave a 4 thumb rating.have a nice day.
5/31/2011 5:05:05 PM •
Cellular...
Answered
on May 31, 2011
Passkey
this is the second person i have seen telling people it does not matter what code you use, maybe you are mis-understanding the question..the passkey for the hfblu series is either going to be 0000 or 1234 thats it..you can always change it but unless you pair it using one of the defaults i have mentioned it will not do the initial pairing to the device. FYI i work for Mizco the manufacturer this is a fact!
8/23/2010 8:43:24 PM •
Cellular...
Answered
on Aug 23, 2010
Need the pairing code for the lt200p
When you want to pair a blue tooth with another device, you can use any code you want, like 1234,1111,3333. It does not have a particular number to function.
The only thing it needs is that any digit number you use must not be lower than four digit numbers.It can be five, six, or even seven, but not lower than four digit numbers.
Have a nice day.
8/23/2010 8:38:13 PM •
Cellular...
Answered
on Aug 23, 2010
Bluetooth doesn't fit into charger box properly so
perhaps you got the headset with the wrong charger dock, you should take it back to the store and test another one there if its the same problem alert the store to this manufacture default...recalls may be in order
7/25/2010 9:04:42 AM •
Cellular...
Answered
on Jul 25, 2010
I need a new manual for model number hfblu-1k
This product is very frustrating. I also need a pin which I don't have and it originally worked just fine with my Blackberry without any PIN.
Cannot get anyone at MIZ to answer the phone or return a call. I've called their support number 1 800 266 4026 but cannot reach a person.
5/25/2010 9:33:50 PM •
Cellular...
Answered
on May 25, 2010
