2007 Subaru Forester 2.5X L.L. Bean Edition Logo
Posted on Nov 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a new Keyless remote for a 2007 Forester from a Subaru Dealer to replace an original one that went bad after 2 years. I have followed the directions in the owner's manual to program it, but can't even get the ''tone'' it is supposed to give to indicate program mode is ready. Do you have any instructions that may be helpful? It came with a battery in it and I am guessing it is OK and not the problem. My Key Remote just has the Lock and Unlock buttons - nothing to open the doors or rear door. Just a plain, simple, OEM factory Key Remote. Thank you. Sincerely, Tom Carlson My email address is [email protected]
Anonymous
Level 2:
New Friend:
  • Expert 36 Answers
  • Posted on Aug 27, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
36
Questions
0
Helped
14109
Points
113
IMPREZA: 2005, 2006, 2007 and
FORESTER: 2005, 2006, 2007, 2008
Check for Immobilizer key on Forester XT models only.
information is always subject to change and correction I bought a new Keyless remote for a 2007 Forester - imp05keylessremote1.jpg
new remote for 2005 Imprezas.
This is not the same remote as the 05 Legacy/Outback remote which also has truck/gate release on the front and a red panic button on the back.
Lock: press Lock button for 2 seconds or so to lock car, and arm optional security system. The car with chirp once and turn signals flash for locked, 5 short chirps and signal flashes if any door is not fully closed. The dome light goes on for 15 seconds and ignition key ring (if present) will light for 30 seconds when unlocked.
Unlock: press unlock one time for driver's door, press again within 5 seconds to unlock all doors inkling rear gate (wagon). The system does not open the trunk.
Panic mode: press and hold lock button for approx. 3-4 seconds to activate Panic mode. I panic model the horn honks and turn signals flash until either the lock or unlock button is pushed again.
Finder mode: Press lock button 3 times within 5 seconds to activate Vehicle Finder mode. The horn will honk once and the turn signals will flash 3 times
Distance: works within approx. 30 feet depending on battery strength, nearby concrete walls and etc.
Audible Chirp On-Off: the system will chirp when locked or unlocked. To turn OFF the chirps, unlock the door and then push both lock and unlock buttons at the exact same time for 2+ seconds. There will be 2 chirps indicating the the audible is off. To turn the chirp back on, repeat the process and the system will chirp one time when it is back on.
Battery: as the battery ages it will only work as you get closer to the car. When a battery is replaced, the transmitter must be re-synchronized with the Keyless control unit. To synchronize, press the lock or unlock button 6 times.
Programming: 4 codes may be programmed.
Sit in driver's seat and unlock all doors. Open and close the driver's door
Turn the ignition key from LOCK to ON position 10 times within 15 seconds. Be sure to stop at both lock and on. The horn will HONK once to indicate transmitter programming mode is activated. Leave key in LOCK position and don't remove it from ignition.
You now have 45 seconds to complete the programming as below.
Open and close driver's door again.
Push either lock or unlock button on the remote you want to program. The horn will honk 2 times when successful.
To continue and program other remotes at the same time: open and close the driver's door and push lock or unlock on the remote. The driver's door must be opened and closed between each remote you want to program.
Done programming? remove the key from the ignition and the horn will honk 3 times.
DELETE old codes? Reprogram 4 times, it will overwrite old codes.
Alarm Security System: optional on all models. When locked there is one chirp (can be turned off, see above), the turn signals will flash and the red 'security' light will start to flash once every 2 seconds except for STi which flashes twice every 2 seconds.
There will be 5 chirps if a door, hood, and trunk or gate is not fully closed
You can also arm the system by using the power lock button on the driver or passenger door as you get out of the car and then closing the door behind you.
Disarm the system: push unlock for 2 seconds
Lost remote, alarm activated? When you can't use a remote to turn off the system: open the door with a key or try to start the car and the horn will start to honk. Turn the key on-off 3 times within 5 seconds and the alarm will go off and you can start the car. It's simple!
VALET mode: To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds. The red 'security' light will then flash 2 times a second until the car is turned on.
System has been Tripped (except for STi): if you unlock the door with the remote and it chirps the signal light flash 4 times, the system has been triggered;
Identification mode: To find out what happened and why the system was triggered:
Open and drivers door, leave it open. Turn ignition key from LOCK to ON 2 times and then leave in LOCK position.
Tripped code: 1 security light flash: a door has been opened, 3 flashes when the impact sensor was triggered, 4 flashes when the ignition was messed with or battery disconnected
1helpful
Programming forester key after battery replacement
if your programing the fob the following link will show you how if your doing the key can only program the remote part of it the key and start will need to be done at dealer the link also explains same
http://www.remotesremotes.com/v/vspfiles/photos/prog/subaru/su-p5e.pdf
2answers
Reprogramming remote start
If it doesn't program, it is probably lived it's life. If it's been in there since 09. When I get cars with after market remotes/security. And they are having problems. The first thing I take out is the remote systems. So for this has fixed every car. Good ones last about 7 years, cheap ones will get you maybe 2 years.
1helpful
I have a 1999 Subaru Forester. The battery went dead after many ,many years. I replaced the battery. Upon connecting the new battery, the car alarm went off. I disconnected the battery from its negative...
Most all aftermarket radios have their own fuse next to the wiring harness plug. Depending on the brand, it may only take a few minutes to pull the radio out of it's sleeve to check for the fuse. Usually, you can pop off the trim ring to see what you are working with.
Programmed remote still won't work
Wrong remote or wrong programming method or system is not operable.
BELT SQUEAK ON 2007 SUBARU FORESTER 2.5X
you have to tighten the belt most likely if it squeals when you just first start it up and then it stops you can put some belt dressing on it and try that. See repair manual to tighten your belt either by using the tension er or some you can use the alternator adjustment to tighten up the belt as well.There could be other reasons as well but not as likely. They are 1. could be the bearings wearing out on one of your tension pulleys. 2. water pump might be going bad keep an eye on your temp. gauge. 3. air conditioner compressor could be shot or bearings going bad. and there are several others that are even more remote so hope one of these will help.
4answers
Keyless entry
locksmith or dealer
Top Subaru Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Oliver Street
Are you a Subaru Expert? Answer questions, earn points and help others
