Texas Instru... Master
- Posted on Nov 23, 2009
Re: Solving a linear equation from TI 83
You have two ways to solve an equation (not just linear) in the TI83Plus
- The solve( command the syntax of which is solve( expr, var,guess, {lower_limit, upper_limit}). Here expr is the expression (without =0), var is the variable you solve for, guess is you estimate of the solution, lower_limit and upper_limit are the bounds of the domain where you are looking for a solution. Of course your guess must be between theses limits.
- The Interactive Solver.
The solve( command
- The solve command is accessed through the catalog of commands [2nd][0] (CATALOG).
- Press [LN] (S) to let the cursor jump to the first command that starts with s.
- Scroll down to reach the solve( command.
- Select it and press [ENTER]. The command echoes on main screen.
- Enter the different arguments: expr, var, guess, etc.
- Close the right parenthesis and press [ENTER].
- Wait for the solution to be displayed.
The interactive solver
Press [MATH][0:Solver]. You see what is on the first picture (I entered K-0.5*V^2). Press [ENTER]. You see what is on the right picture.
In the interactive solver you enter a value for all the parameters, constants, for all, save the entity you are solving for, here V. So you must clear the 0 to the right of the = sign after the V. when finished you press [ALPHA][ENTER] (SOLVE).
Here is what I get for the Solving a linear equation from TI 83 - 7b60093.jpgle I chose.
Left -rt=0 shows that the root was found to within the calculator's tolerance.
Hope it helps.
Thank you for using FixYa.
