Gateway M305CRV Notebook Logo
Posted on Nov 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Gateway laptop says my sound device is working properly, but the sound only works if headphones or speakers are plugged into the jack. how do i fix this?
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on Nov 16, 2009
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1018141
Points
8362
It sound like your headphone jack is the default sound device. Go to control panel > sounds > look at the devices listed. Click on the speakers that have a device connected to them. You may have two selections for speakers, but one may be tied to a sound device and the other to headphones. Highlight the sound device and click on make this device the default sound device and hit apply.
No sound coming from speakers
uninstall audio driver and install it again.
Hello, i cant hear the microphone over the speaker
Make sure your microphone is not muted in the control panel, under sounds.
No sound from new NV52 gateway laptop, checked all the obvious things, the driver is working, everything in properties and device driver is working, nothing is muted, just no sound, not even at boot up.
if u look sound driver in device manager however it canot be stall.so look it in control panel in speaker sign if here is deam and we can not move any setting .it is instalation fault and not using proper driver. then we can say it is hardwere fault.
2answers
No sound in Gateway mx6030 MA2 Laptop
Make sure the audio cable is plugged into the MB properly.
No sound driver working on my gateway notebook pc
Did you check the Device Manager, the audio driver, has it a yellow ? against it or is it OK and enabled? If it is has the MUTE button been ticked?
If it has a yellow ? against the audio driver then the correct audio driver was not installed. Go to the Gateway Support/download page to download the correct XP driver for your model laptop's audio device and install it.
If the sound still doesn't work check Device Manager to see if the driver was installed and working.
Gateway Mx6440 Sound Problems, installed Vista
Did you download and install this particular driver from Gateway:
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=10773&os=10954&type=10096
This is the specific Vista driver for your computer. If you have been trying others, your hardware probably will not work. Hardware compatibility is an issue with upgrading to Vista. You need to make sure you are getting the right drivers from the device manufacturer, and sometimes you might find none available.
No sound
TRY INSTALLING AN AC'97CODEC DRIVER FROM REALTEK.RICHARDM69
No sound device
remove the first sound device, then restart your computer, to see if vista will see that item. you may need fresh vista drivers for this to work..
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
