2000 Dodge Neon Logo
Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 Dodge Neon engine light on. Trip code
2000 Dodge Neon engine light is on. Trip code 88888.8. Car is running fine. Just filled it with gas today. Gas cap is on. Ideas?
Anonymous
Level 2:
New Friend:
  • Expert 97 Answers
  • Posted on Nov 11, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
97
Questions
0
Helped
36820
Points
308
Autozone will scan the engine light for free. start there
Wont shift gears
Dodge Neon Questions - 04 neon will not go into high gear ...
www.cargurus.com > Questions > Dodge > Neon
CarGurusNov 3, 2012 - 04 neon will not go into high gear - 04 neon won't go into high gear. changed transmission fluid. (it tried to change after fluid was changed) gas cap ... ... Car: 2003 Dodge Neon SXT, automatic transmission. As of today, I have ...
Dodge Neon Questions - 2005 Dodge neon does not shift ...
CarGurusApr 6, 2014 - Your cars computer gathers info on speed in order to shift gears properly.... then you won't have a speedo and the ECM will not tell the TCM to shift gears in the trans. .... Car: 2003 Dodge Neon SXT, automatic transmission.
Neon wont shift out of first gear auto. - DodgeTalk : Dodge Car ...
www.dodgetalk.com > ... > Dodge Neon - General Talk
Jul 30, 2011 - I have a 2003 dodge neon se and it will run and drive. The transmissonwill not shift out of first gear. Where do I start? Compare to Toyota Tundra. Get Tundra on ... 2000 Stratus won't shift out of First Gear
Mar 14, 2007
Not shifting out of Second Gear???
Jan 15, 2007
46RE wont shift out of first at full throttle.
Nov 17, 2006
Transmission wont shift
Nov 3, 2005
More results from www.dodgetalk.com
3helpful
2answers
Dodge neon shuts off while driving
the neon has a problem with the wiring near the engine mounts in that it breaks or otherwise looses connectivity and that set of wires are for the cam position sensor
with that sensor not reporting to the ECM , the engine is turned off when there is not reaction from the engine , connection is restored and so ti start up again
check in the wiring harness in that area for the problem
1helpful
My 2004 dodge neon had it's check engine light come on the codes that came up are P442 and P456 what do they stand for?
they are for evaperative emmisions leaks.usually its a loose gas cap that causes these codes they are small leak codes.check gas cap, give it a couple of turns more to be sure its tight.
the car has to make 3 consecutive trips that detect no leaks before light will turn off.each trip has to start with a cold engine gas level between 15% to 85% of full.
or clear codes with code reader and drive car as usuall. if a leak is detected twice then the light will come on again.if it does then you will need to look for cracked vapor hoses,leaking canister etc
Check engine light comes on and engine starts chugging.
THERE MUST BE A SENSOR PROBLEM YOU NEED TO CONNTACT A DEALER AND FIND OUT WHAT THE CODE REPRESENTS
Check engine light code 51
there is a code 51 first of all, try putting octane boost in the tank, there has been several completes all across the country of watered gas, i have a 96 and a 95 neon and within days of filling both up the code 51 came up. the boost helped 1 and the MAP sensor had to be replaced on the 96. hope this helps
2answers
I just bought a 2000 Dodge neon for my nephew and it has 174000 miles. When I start the car and start going - sometimes the car will shake and make loud noise uner the hood and If let the gas padel go and...
I don't even know where to start, Here is a link for you and hope it's going to shine some light at the end of the tunnel. it's going to give you instruction on to how to retrieve DTC codes and possible causes to why your neon is doing what it's doing.
Good luck and keep me posted, be glad to help you out. http://www.allpar.com/fix/codes.html There are also links there for related problems to your neon too.
2005 Dodge Neon drives fine but the check engine light is on
you have to get scanned for fault codes..possible camshaft sensor if you have starting issues..if car is working fine,could be an evap leak..let me know
2003 Neon air coditioning shutter
the AC servo that kicks up the engine idle speed when the AC is no..Is stuck or faulty...Replace it.
2answers
Engine Light always on
If Your Check Engine Light Is One Take It To A Local Autozone And Have Them Run Their Diagnostic On It.
This Will Provide You With The Exact Code For What Is Wrong Then You Can Come Back Here With The Codes And We Will Tell You What The Code Indicates . Best Of All Its FREE
Engine Warning Light is on, earlier car sputtered and poor power
get the car code read for starters then let me have the code
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
