Constant green blinking light Mitsubishi tv WS-65513
The green led light constantly blinks. I tried the reset button and green light is still blinking. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board. via email? Thank you in advance for your help. Your help is much appreciated!
senioM seD
We have a Mitsubishi WS73713 (wasn't listed below) we have had the flashig green light. The tv didn't work for 7 days, green light flashing the entire time. Day 8 no flashing green light & the tv worked for about 5 days, then same thing, flashing green light & tv won't work. It has done this on & off for about a month. It has not worked since December 25, today is January 6. What can I do??? I need any help anyone can give me. I don't know who to call, is this something we can repair ourselves???? Help please.
we are having the same problem the green light keeps flashing and tv wont go onwe are having the same problem the green light keeps flashing and tv wont go on
You can't post conmments that contain an email address.
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board. via email? Thank you in advance for your help. Your help is much appreciated!
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category. http://servicemanuals.vstore.ca/
Good Day, jcarnell;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in. CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V). The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board. Good Luck, big IRISH.
First wait 90 sec. after power is applied before turning on. If still blinking forever "this is a common problem with the mitsubishi V23 chassis, There are four 1000 UF capacitors in the DM module that go bad. Location #'s c9b01,c9b02,c9b10 and c9b11. The DM module is the large steel card cage on the left side when looking inside with the back off. Once you get the cage out, remove the board. The caps are the larger ones on the top of the board. They will more then likely be bulged out on top or exploded. Replace with 1000 UF @16V or better. This should get you going again. I've done about 15 of these repairs in the last year. Note: try not to mangle the copper grounding fingers. Good Luck.
Have you looked at the DM board fix yet that's available here. http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair
Check it out. If the inside of your TV set does not look like this, you will need to get the service manual to disassemble the set and get to the DM board, but use the rest of the guide to repair the board. If you are successful, you will save almost a 1000 bucks! Good Luck
turned the tv off 4 days ago when i went to bed , tried to turn it on the next morning. nothing but a blinking green light?????
HELP
SCOTT
asas
wd 62825 same problem
