It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
My name is Dane and I am going to help you solve your problem. You said that the "Pulley" is loose when the blades are disengaged. I hope you meant that the belt is loose, because the pulley should never be loose. If it is loose, you should remove the pulley and make sure the KEY inside the center hole is still ok. Sometimes when the pulley gets loose it chews up the KEY and allows the pulley to turn on the crank. If the KEY is ok, just reinstall the pulley and tighten it.
I believe that your belt is probably just stretched and worn. The mower deck belt gets it's tension from lowering the mower deck. the lower the deck the tighter the belt. Just replace the belt. I hope I've helped! Thank you! Dane
No longer need this information. Thanks.
