Apple iPhone 3G Logo
Posted on Nov 09, 2009
Unable to connect to other bluetooth devices - Apple iPhone 3G
Anonymous
Level 1:
  • Contributor 14 Answers
  • Posted on Nov 09, 2009
Anonymous
Contributor
Level 1:
Answers
14
Questions
Helped
13530
Points
79
Do you have bluetooth turned on and allow pairing?
Apple suggests this: http://support.apple.com/kb/HT1838
Also many older and "cheaper" bluetooth devices do not work with iPhone. Check out this article: http://news.cnet.com/8301-13544_3-9740876-35.html
Hope it helps!
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
2helpful
3answers
Speaker wont connect to bluetooth
Go to your Bluetooth settings and forget the device. Then re-pair it for a fresh connection. This worked for me
2helpful
2answers
My htc mozart is unable to connect other bluetooth devices it is saying not supported.how to connect my bluetooth to others to transfer data or music.
Unfortunately, your phone doesn't have File Transfer Profile (FTP) in bluetooth, you'll need to use its USB cable to transfer files between PC and phone, it's a standard micro-USB (5-pin micro-USB 2.0) cable.
My nokia 7610 says unable to perform bluetooth operation
When you get an error "unable to perform Bluetooth operation", it means that one of the Bluetooth devices is not communicating correctly. It could be your phone, or it could be the Bluetooth device that you are trying to connect to. And that will depend on the device that you're connecting.
There's a possibility that the Bluetooth requirement of your device is not supported by your Nokia phone. Example, you are trying to pair up a Bluetooth handsfree car kit. "IF" the phone does not support the handsfree profile, then you will get this error message.
So, you need to make sure that your device and your phone is compatible with each other. Second, try to pair up the phone into different Bluetooth devices, like phones, headset, etc. Doing this will let you know if the Bluetooth on your phone is working or not. If it works with another Bluetooth devices, then the problem has something to do with the device that you are trying to connect to.
Thank you and good luck!
Jul 31, 2010 • Nokia 7610
1helpful
I cannot get it to connect. My Palm Centro recognizes it, but says that is unable to connect even though it has done so in the past.
Try disconnecting the bluetooth device then turn the bluetooth off then hold the power button untill the bluetooth shows a solid red light then try connecting the bluetooth between your palm and the bluetooth device hope this helps
Bluetooth problem
select show to all in blutooth setting to connect your bluetooth with other devices..if you are using ear piece (bluetooth) first add it in your devices connect it..and once it connected select hidden..so no other bluetooth device can interupt
Tom Tom Unable to find my phone
Most Motorola mobile phones can only remain discoverable by other Bluetooth devices for a period of 60 seconds. Occasionally this period is too short to complete the pairing process with a TomTom device.
Go to:
http://www.tomtom.com/support/index.php?Language=1&query=motorola&FID=3702
My Katana and Bluetooth
Some devices require you to set the device for recieving data. In the Bluetooth, menu there should be an option to "Receive File" or photo.
2answers
Bluetooth
from ur bluetooth link open device history and select the blue device and delect, some of the devices.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
