Computers & Internet Logo
Posted on Nov 07, 2009
Windows Vista is incompatible with delphi 7.0. Is
Windows Vista is incompatible with delphi 7.0. Is there a fix?
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Nov 07, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
3460
Points
19
Not really pal this is why vista is rubbish upgrage to 7 or downgrade to xp windows 7 lets you run xp .exe on it but vista never had the option to do this because its rubbish have alook around i think on rapidshare there is a download link for windows 7
Sims3 is incompatible
I assume you running it on Windows 7 32-Bit. Now before you trying the tips below, do make sure your computer is compatible and meet the Sims 3 requirement.
The Sims 3 can be run on a PC with Windows XP and Vista, and on a Mac. However, there is no official Windows 7-compatible version. This means that Sims 3 will not install on Windows 7 properly.
To fix this error, you need to run Sims 3 in Compatibility Mode. To do that, simply right-click the Sims 3 icon, select Properties and then select Compatibility. Then check the Run this program in compatibility mode for box and select Windows Vista or Windows XP SP3. The game should work fine.
tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 • Computers & Internet
2answers
Can I use my Borland Delphi 5 CD for installing Delphi 5 on my new Windows 7 computer
This is the last version of Borland dBASE for Windows (next version is Visual dBASE 5.5).
This is VERY unlikely to work as it was designed for much earlier operating systems.
Windows 7 is a very different architecture - maybe it time to upgrade.
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Can I install my software in windows 7
before you can install the windows 7 operating system, download first the windows advisor software that allows you the check your computer if the components of your system is capable for having a windows 7 operating system, it also checks your computer if you have incompatible programs and applications if your thinking of an upgrade from windows vista to windows 7.
if your planning to do an upgrade check the version of your vista OS to see the compatible version of windows 7.
i hope this helps
Upgraded from windows vista to windows 7 and and I am told photo explosion deluxe version 3 is incompatible with windows 7. what can be done to make it compatible?
you should contact the manufacturer because they have produced a version 4 which is compatible with Windows 7 see the link below. The company was saying they were working on a driver to fix the compatibility issue with version 3 but they obviously have one.
http://www.novadevelopment.com/software/photo-explosion-deluxe-129012
My scanner Compaq S200 is not working with Windows Vista
As I'm sure you have already heard, Vista has been replaced by Windows 7 due to many software incompatability issues. My best advice would be to get rid of Vista and either downgrade to Windows Xp or upgrade to Windows 7 as these two are far more stable and compatible with most software applications.
Best wishes,
Graemevm
1helpful
2answers
Installed windows 7 - printer appears incompatible with newer version windows - will there be a fix coming?
yes there should be in the next couple of months also try the vista drivers that might fix it
Hoyle Card Games
Do nothing, Vista is incompatable with Hoyle 2005 to 2009. Wait tille Windows 7 comes out. A word to the wise.
Printer is incompatible with Windows VISTA
Not according to their website, is is not incompatable.  You need to download and instal the new software and drivers for VISTA,thats all.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=239140&prodTypeId=18972&prodSeriesId=239135&swLang=8&task
Top Borland Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
