Dell Inspiron 710m Notebook Logo
Posted on Nov 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The sound only works when the screen is in a certain position
  • Brad Brown May 11, 2010
    That is weird. THe only thing that could be doing that is the cable to the lcd from the motherboard or loose hinges. What position does it have to be in to work
Larry Chandler
Level 3:
President:
  • Master 1,149 Answers
  • Posted on Nov 06, 2009
Larry Chandler
Master
Level 3:
President:
Answers
1149
Questions
0
Helped
451559
Points
3903
Hi:
The Dell 700 series laptops have a common fail on the sound, because of a some what fragile ribbon cable that feeds the speakers that are mounted just below the LCD display. Your sould still works, just the ribbon cable is cracked, from opening and closing the lid.
You can find the part on ebay for less than $20, but it does require a bit of disassembly to get it swapped out.
1999 olds aurora wont run unless hold key in a certain position
sounds like the ignition switch has an internal problem and requires changing.
Tablet not working i turned brightness down now i ca n not see
Can you see whats on the screen when you angle it in certain positions? What I mean... is it just the screens back light that isnt working or is the screen showing nothing?
1helpful
Msi wind smoking from side
This sounds like the cable from the motherboard to the screen.
My xbox 360 mic is acting up. I can talk to people but I can only hear them if the plug is twisted to a certain position
Sounds like a wire broke inside. That's why it only works when you have it in a certain position. Unless you are good at splicing wires, move the wire till you get it to work, and wrap it in that position, then don't move it at all. Good Luck.
The screen on my laptop has a rainbow on the right hand side. It is more than a third of the screen that is affected. The laptop worked yesterday and i am the only person who has used it.If i hold the...
Sounds like you are in for a screen replacement which is probably more costly than buying a new laptop.
An alternative is to use a desktop monitor and forget the laptop screen.
Only right speaker is working left doesnt sound
What has most likly happened in this case, is that either:
a) the wire has been tampered with, and has caused the left speaker to cut out,
b)the speaker settings are set to only play sound through the right speaker.
I recommend you see the bottom right of the computer screen, and look for the speaker icon. Right click the icon, and then select 'open volume control'. After doing this, make sure that all of the 'balance' bars(located at the top of 'volume control') are in the centre, and not at either side.
If this doesn't help, then I'm afraid you can only really purchase a new set of speakers, or have a fiddle with the wire, and see if there is a certain position or place the wire can be which makes both speakers work. If there is, tape the wire in a place/position which works.
Good Luck!
Screen blanks out on certain positions on laptop
This sounds like you have a short in the LCD ribbon cable and it will need replacing, in most cases you will have to replace the screen but if you can find the exact ribbon cable, replacing should do the trick.
Acer Aspire 5100
Sounds like the power jack is loose if you have to hold it in a certain position. As for the screen your inverter might be shot. Try connecting an external monitor to your laptop and see if you get a display.
LCd open in certain angles makes screen darker and sound disappear/noisy
its natural dude....
laptop dnt hv long lives
neither do the batteris hv
try to change the batteries
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
