There's no treble & bass setting although checked that everything is according to the manual. This is a new install.
You DO NOT NEED imprint software to tune your bass/treble so don't waste your money. Go to "A. Sel" then graphic or parametric equalizer based on your settings in "setup," then go through either the 5 or 7 bands as you have setup and adjust for each frequency. On graphic EQ, you have more dynamic control. These are what each band represents by frequency from 1-7: 60hz, 150hz, 400hz, 1khz, 2.4khz, 6khz, 15khz. Hope that helps.
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Bass and Treble controls allow you to adjust each setting from
-7 to +7 once you have calibrated your vehicle's interior sound with the optional Alpine IMPRINT software.
Is this what might be causing your setup not to work?
Most premium professional installers will offer this, if they install alot of Alpine equipment.
Crutchfield offers to rent you the unit for, I believe 50 bucks, otherwise, it is a couple hundred bucks!
http://www.crutchfield.com/App/Product/I...
If you feel like I helped, try to change my rating to FIXYA, please.
Any more Q's give let me know!
I'm very impressed!!!!!!!!
And you seem to know my problem so so so well.
I've not done the calibration like you mentioned. Is this requiring the KTX100eq soffware+hardware? I've check this on the Alpine website that there's this thing. But so unfortunate i don't have it :-(
TQ.
please tell me how to adjust bass and treble?
thanks
Just installed this in my truck tonight and it goes from Subwoofer straight to Fade/Balance and skips over Bass/Treble. I live in Italy..US Mil and not sure if there is a place out here, Any suggestions. I also am getting a little whinning sound through the speakers if the volumme is down. Like engine noise but I added filters and everything and still? Is the Alterator problems
