Televison & Video Logo
Anonymous Posted on Nov 04, 2009
Dvd player will not play dvds
(APEX Digital DVD/CD/MP3 player AD-1130W) When dvd is inserted the dvd player reads LOADING, after a time of trying to load the player reads NO DVD. The dvds will play on other players. Why is this happening?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 05, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
813
Points
Motor was not working. Disposed of old player and bought another dvd player
Nanny
Level 3:
Genius:
  • Televison & ... Master 2,351 Answers
  • Posted on Jan 10, 2020
Nanny
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989384
Points
7262
Normally, if you can't play a DVD disc, first you need to check out whether if it is the problem of the DVD player or the DVD disc. You can try playing the DVD disc on some other DVD player machines and DVD player programs on your computer. Then you can play some other different DVDs on your DVD player to see if there is any issue with your DVD player.
I can think of some issues with the DVDs, which can be scratching problems, region code problem, Cinavia protection, disc format problem or it may be a data DVD which cannot be directly played on DVD player machines.
GPX D1816 DVD
This is a common situation, this an indication the laser assembly pickup is failing, it is far cheaper to replace the player than have it repaired.
1helpful
1helpful
Apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Replace DVD remote
Check this eBay auction for the remote:
http://cgi.ebay.com/Apex-Digital-AD-1225-DVD-Player_W0QQitemZ250397256142
Note, it comes with the DVD player free.
It's only $15.
I need a manuel,i cannot find mine
it reads unknown disc with every dvd movie we try to play
1helpful
Displays "NO DISK"
The message indicates that the system failed to read the index portion of the disc. Try cleaning the lens using a cotton swab and alcohol. Try playing a music CD as well. If hte CD plays but the DVD continues to fail, you have a failing optics assembly that needs to be replaced. This is the most common symptom of failing optics. DVDs will fail while CDs will play.
Keep us posted.
Dan
1helpful
4answers
Dvd player not loading
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Wrench
2answers
WHY WON'T MY DVD PLAYER WORK?
you can try this unplug the unit , you'll need alchohol, q-tips, screwdriver open it and look for all the flat cable connectors. be carefull and remove 1 side at the time ,and clean the contacts, put them back on , see if you can see the optic laser inside the mechanism it looks like a crystal eye, if you can reach it be gentle and clean the dust may it have. or buy at radio shack a cd cleaner. if after that your dvd don't work with dvds try a regular cd. if it plays music the laser its bad nothig else you can do. cheaper to buy a new one
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
