"belt position not sure is correct," from your description above
The first thing to do would be make sure belt position is correct, connected and tight.
This system is quite simple, the belt goes in the pulley on the engine shaft and the pulley on the transaxle only, nothing else. Using a short piece of rope or anything else readily available, temporarily tie down the safety bail (handle) and engage the drive handle. Now check your belt, it should be fairly tight and you should not be able to turn the transaxle pulley without considerable effort, if it is easy to turn, replace the belt. Now release the safety bail (handle)
If the drive belt seems to be working okay as above, remove the front wheels and inspect the gear teeth in them. If the outer half of the teeth are worn down more than 1/2 the original size as compared to the inner half, replace the wheels.
While you have the wheels off, if you have a couple of blocks of wood or similar items, set one under each corner of the front of the main frame outside the arch of the blade and start the engine, engage the drive and observe the pinion gears, they should both be turning. If they are not, then you have a bad transaxle and are going to have to either replace it , use it strictly as a push mower, or replace the mower.
Testimonial: "Thank you for your time to help me. I am very much appreciated. Tony"
Looking for a diagram for the proper way to install a belt on a 38 inch mower deck
Consult your owner's manual to get the proper part number for the drive belt needed for your particular lawn mower model and purchase it.
Step 2
Turn your lawn mower on its side or put your riding mower up on blocks so you can get to the underside of your mower's deck.
Step 3
Clean the underside of your deck. This can most easily be accomplished by carefully scraping the underside of the deck with a long handled flat blade screwdriver. Remove any pieces of drive belt that are still attached to the pulleys that are visible.
Step 4
Locate the tensioner. This is a pulley that can move when it is loosened. Use your ratchet to loosen the bolt holding the tensioner in place. Allow the tensioner to move closer to the other pulleys.
Step 5
Check your owner's manual for the proper way to position your drive belt over the pulleys. On most models the drive belt simply goes around the drive pulley, the tensioner and the pulley connected to the blades, but some models are slightly different.
Step 6
Pull the tensioner tight until there is less than 1/2 inch of play in the drive belt when you push on it between pulleys. Tighten the bolt holding the tensioner in place once the belt is as tight as the owner's manual suggests.
I am askinf the belt position can be possible idetified if it is Correct ot Not.
I said Engin and blade is running just good.
I do not know anything else related my question.
I stated the model number, and no specific info about this model.
Thanks you very much! Mark tried help and I am very much appreciated.
Tony
