Heating & Cooling Logo
Posted on Oct 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change the orfis from propane to gas on a empire 40,000btu
How to change the orfis from propane to gas on an empire 40,000 btu furnace.
Anonymous
Level 2:
  • Expert 89 Answers
  • Posted on Nov 01, 2009
Anonymous
Expert
Level 2:
Answers
89
Questions
Helped
35567
Points
143
What is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Can u get right orfis from propane company to fiut heater
You need a conversion kit reg injectors etc . Some models do not convert check with makers first .
Empire wall furnace pushing down the pilot button trying to light the pilot found too much gas flowing
Is the button on the gas valve or a red button in the line to the pilot assembly? If its in the line, there is a regulator upstream of the button. If the gas is coming from the gas valve, there is a small screw covered hole in line with the pilot line in the gas valve. If neither of these apply, you may need to replace the orifice in the pilot assembly. Let me know how it goes.
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
2answers
I have a Miller furnace with central air. I am looking to change to a propane gas heater. Looking for cost of Coleman furnace, or can a miller oil furnace be changed to a gas furnace?
Yes it can do but you will be better off by gone to a gas heater. MY own furnace was chance over to propane and didn't workout to good. Less then ayear i have put in a new heater. Ken's Repair
How to change gas orfice to propane glass smokes up. soot
Is this unit originally set up for natural gas? If so, the burner oriface and the gas valve need to be retro-fitted to propane. This is something only a qualified service technician should attempt as an incorrect retro-fit could cause an explosion resulting in someone getting hurt or even killed.
Trouble shooting Hayward pool furnace
Big enough propane tank? proper pressure reducing valve on the propane? Check both of those.
Top Empire Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
john h
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
