Apple iPhone 3G Logo
Posted on Oct 30, 2009
How do you remove synced photos from the iphone?
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Oct 30, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
31998
Points
72
You can do this in iTunes - with the iPhone connected select the 'photos' tab and deselect the folder containing the photos, then hit Sync to remove them.
Alternatively, just move the photos to a different location on your hard drive (out of any folder that is set to sync to iPhone), then connect to iTunes and hit sync.
Hope that helps!
  • ciccarem May 18, 2011
    Mate ur a champ... Really don't know why everyone raves about apple..... Pretty on the outside and a headache on the inside.... Thanks.
Otavio Cunha Fernandes
Level 1:
Habit-Forming:
New Friend:
  • Contributor 7 Answers
  • Posted on Mar 28, 2016
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
7
Questions
0
Helped
8334
Points
24
Here's a guide to show you how to use iTunes to delete iPhone photos synced from computer.
  1. Start iTunes and go to "Edit > Preferences > Devices", and check "Prevent iPods, iPhones and iPads from syncing automatically".
  2. Plug iPhone into computer via USB cable, and authorize the computer. iTunes will recognize your computer and display the iPhone icon at the upper right corner.
  3. Click the iPhone icon and choose "Photos" in the summary panel. Check "Sync Photos from" and then choose "from folder". Select the folder you stored your photos.
  4. Then iTunes will sync the photos from the folder to your computer. If the folder is empty, iTunes will also erase the photos in your iPhone and sync the empty folder to your iPhone.
With iTunes, you are able to delete iPhone photos synced from computer. But the trick will sweep out all the original photos in your iPhone library. If you want to delete photos from iPhone separately without deleting the ones you still need, you can use the third-party iPhone transfer software to finish the task.
http://www.leawo.org/tutorial/how-to-delete-iphone-photos-synced-from-computer.html
1 Related Answer
Anonymous
  • 46 Answers
  • Posted on Nov 24, 2008
SOURCE: The sync photos says that the existing photos would be lost
I don't think that there is a solution... Apple appear to re-use the photo filenames at each syncro.
They should have used a combination of the date/time...
The only thing you can do is place your photos in a new directory each time you sync.
How to transfer photos from canon camera Sx530 to iPhone
You can export photos on canon camera to computer with SD card first. And then transfer photos from computer to iPhone. Just follow the below steps to learn how to transfer photos from computer to iPhone.
Using iTunes to sync photos with iPhone is also easy. As a media management center, iTunes helps you easily manage data and files (purchased and non-purchased) on your iOS devices (iPhone, iPad and iPod). You could easily sync data and files to iPhone with iTunes. But you should be very careful of the syncing function of iTunes because it is a double-edge sword. Once wrong click, you may lose data in your iPhone. You'd better back up your iPhone to iTunes before you try to sync photos to iPhone with iTunes. The following steps are going to show you how to transfer photos from PC to iPhone with iTunes:
1. Plug your iPhone into computer via the USB cable. Launch iTunes if it doesn't launch automatically. Make sure that you have the latest version of iTunes.
2. Click on the device icon in iTunes.
3. In the sidebar on the left side of the iTunes window, click Photos tab under your iPhone.
4. Click the box next to "Sync Photos". If instead you see "iCloud Photos is On", all of your photos and videos are already on all of your devices that use iCloud Photos. You don't need to sync them through iTunes.
5. Choose the app or folder that you want to sync from. If you choose to sync a folder with sub-folders, the first level of sub-folders will appear as albums on your device.
6. Choose to sync all photos and albums or selected albums.
7. Select "Include videos" to sync the videos from your app or folder too.
8. At last, click the "Apply" button.
You may need your Apple ID to start the photo syncing. If iTunes asks, type your Apple ID into the blank, and then the synchronization starts.
But as mentioned above, iTunes is a double-edge sword. iTunes has very strict content management system, and the software never allows users to transfer files which are not got from iTunes back to computer or iTunes Library. So when you are transferring photos from PC to iPhone, iTunes wants to sync with your iPhone. Once syncing with it, you may lose the files which are not got from iTunes.
For more details, check: How to Transfer Photos from PC to iPhone
Can I transfer pictures to ipad
Yes, there are lots of methods to transfer pictures from computer to iPad. Just follow one of the methods shown below.
For more methods, check: How to Transfer Photos from PC to iPhone
2helpful
5answers
How do I delete unwanted photos from my tablet?
Just open gallery, find "select" , do it then use the same 'button' to bring up a list of options. 'Delete' should be there.
How to transfer photo from view nx2 to iphone 5
You can export photos on view nx2 to computer first. And then transfer photos from computer to iPhone with iTunes/iCloud or other tools. As for transferring photos from computer to iPhone, you can follow the below steps.
4helpful
3answers
Delete photos from my apple ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to remove the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More detailed guide about how to delete photos from iPad.
www.iphone-mac.com/how-to-delete-photos-from-ipad-camera-roll.html
2helpful
6answers
How do you delete photos from ipad?
To delete photos in 1st generation ipad tap photos,tap photos again then tap photo you would like to remove.When in full mode trash can is available.
For 2nd generation and new ipad,tap photos then edit.Tap each photo to add check then tap delete to remove all checked at once.Please Rate
How do i sync photos onto my iphone
First of all, we would like to talk about the official solutions provided by Apple: iCloud and iTunes, both of which help Apple users to manage their data and files on iOS devices (iPhone, iPad and iPod) effectively. You could transfer photos from computer to iPhone with iCloud and iTunes respectively:
Using "Photo Stream" to transfer photos from PC to iPhone automatically with iCloud is pretty convenient. Go to "Settings > iCloud > Photos (Photo Stream on iOS 6)" and then turn on My Photo Stream. Then get your iCloud started on your PC. In the iCloud Control Panel, Check the "Photos" and then enable the "Photo Stream" option. After that, import the photos into the "Photo Stream" folder on your PC, and then you will be able to view the photos on your iPhone. Using iCloud to transfer photos from computer to iPhone is easy, but this method needs Wi-Fi connection. Only over Wi-Fi connection can iCloud sync photo on PC with iPhone. The following steps will show you how to transfer photos from PC to iPhone with iCloud.
Jul 09, 2011 • Cell Phones
How to delete pictures?
Just tap the photo and tap the trash can logo below, If fails
Do the following.
1. Open up itunes and click on your iphone.
2. Select the photos tab.
3. Where is has the ticked box "sync photos from" just click on the box again.
4. Itunes will ask if you want to remove all previously synced photos, Click delete!
2answers
27helpful
4answers
Deleting pictures from my phone's photo albums
These are all "closing the door after the horse has bolted" - suppose your iphone already has photo albums you don't want. How to delete them??
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
