Gigabyte recommends to install uniform modules to operate the memory in dual channel mode. Your current configuration will not operate in dual channel mode.
If you install four memory modules at the same time, the Dual Channel Technology will operate only when those modules have the same
memory size and type.
I recommend that you either install four 256MB memory modules, or four 512MB if you can afford.
I also recommend that you install max four 512MB (ie 2GB) modules for if you exceed the 2GB limit then you will have to install XP-64 or Vista-64 Bit to make use of it.
A 32 Bit system cannot fully utilize memory in excess of 2GB.
Testimonial: "thanks for the prompt response."
Definitely not. Dual channel technology requires that the 2 RAM modules installed in each bank be of the same capacity, data rate, & even better be from the same manufacturer.
Thanks. Is it worth activating the dual channel?
