Homelite Mighty Lite Lawn Trimmer  Logo
Posted on Oct 28, 2009
What is the proper gas oil mix for a homelite 25cc weed eater
trythis1
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Oct 29, 2009
trythis1
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
10732
Points
68
2 cycle? then 40:1 gas to oil mixture
Pls HELP What gas/oil mixture for homelite 2006 UT20026 & 1999 UT20724 both r Straight shaft Weed eaters, Sam
Just buy and use a good multi-mix oil. I have been both using and selling a Pro-mix that when mixed with fuel can be use any 2 cycle 16-1 to 50-1 mixes. Saves a lot time hunting for different mix containers. Other than it is 40-1.
1helpful
What fuel do I put in the weed eater gas blower fb25?
Regular unleaded with whatever oil mix the fuel cap has on it.
Try to avoid gasoline with high ethanol content. You can look online and find alcohol-free gas in your area. You wont regret it!
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
2answers
How do i mix the gas/oil on a 25 cc 2 cycle craftsman weed eater
The specs say 40:1 so 3 - 3 1/2 OZ of 2 cycle oil in a gallon of gas.
1helpful
I have a Homelite Gas Weed Eater. Model BC800. What type of oil does it take and what is the correct mixture of gas to oil?
Any name brand two cycle oil should be good like Echo, Stihl,Opti-2,Shindaiwa. Homelite even makes there own two cycle oil in a pre measured bottle. Mix it 40:1 which is 2.6 oz. of 2 cycle oil to 1 gallon of gas.
Sep 04, 2011 • Garden
What is the gas to oil ratio for weed eaters?
Most gas weed eaters use 2-cycle engines. For the Homelite 2-cycle engine trimmers, use a 50:1 ratio of gasoline to the Homelite lubricant. (For 1 gallon of gas, add 2.6 oz of the oil.)
Many Homelite tool manuals are available here: http://www.homelite.com/service_support/product_owners_manuals . Scroll down to find your string trimmer.
I hope this helps.
I need to know the gas to oil ratio on my 17" 25 cc craftsman weed eater.
4 oz of a generic 2-cycle oil to a gallon of fuel is the typical mix.
I hope this helps.
Just want the gas oil mix for a 25cc weed wacker
if using sthil oil the mix is 50:1 if not then its either 32:1 or 40:1 not to much dif
2helpful
2answers
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
