Hi, You should be able to depending on how your DVD is connected up. If it is hooked up using a yellow, red, and white lead (RCA. Common lead with a pin in centre of plug) there it should be no problem. On your TV there should be a set of sockets of the same colour. These should say monitor out, our output. Basically this set of plugs will send the picture and sound of whatever you are watching on the TV. If you connect from your monitor output sockets on your TV, to the input on your DVD recorder (will likely say AV1, or input on your DVD recorder) then it should record your video. You just have to make sure that the picture on your TV is the video you are playing, and the channel that is set to record on your DVD recorder is AV1. (You may also have an input at the front of your DVD recorder that says AV2 or input 2.) As long as you set your DVD to record the input set of sockets you plugged your cable into it should work. This set up will not alter the operation of your DVD or TV.
Testimonial: "Many thanks, it appears simple enough, I'll let you know if it works satisfactorily!"
