Pioneer VSX-819H-K A/V Receiver Logo
Posted on Oct 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pioneer vsx-819H: MCACC setup won't display on tv
Pioneer vsx-819H: MCACC setup won't display on tv monitor although monitor was playing correctly. HDMI wired from cable thru receiver to tv monitor. Was displaying tv signals fines, but after MCACC attempt..no sound..help. I'm quite sure all cables are set up okay. Zone 2 has been turned off.
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on May 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
6165
Points
37
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Grand Canyon Tech
Level 3:
  • Pioneer Master 3,867 Answers
  • Posted on Oct 24, 2009
Grand Canyon Tech
Pioneer Master
Level 3:
Answers
3867
Questions
Helped
1177334
Points
12717
I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
please press the accept button as I worked hard to answer you question.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
  • Greg Alexander
    Greg Alexander Apr 26, 2014
    I don't think that the hdmi cable is an issue because it worked fine on both units for about 8 months and then stopped working.
Pioneer troubleshooting
Have the pioneer vsx-1016txv-k - During MCACC setup It indicates an error with the rear right surround speaker. Yet during play in db mode - Neo & etc the RRS speaker works! RRS does not work during the MCACC set up. Can you help resolve. Thank You Joe
My pioneer vsx 921 switched off while playing loud. ADv MCACC is flashing and it is not powering on? What could be the problem?
Your unit is locked in protection mode. Hold the advanced surround button and the power button to turn it back on. If it shutdown right away, then you shorted out the amp and need to take it in for repair.
Pioneer VSX-1016V with a flashing MCACC
For me on vsx 1016 txv it was ENTER and DVR/VCR2 for 2 seconds. Blue power power button lit up. Then it went back to MCACC flashing amber. So probably blown amp.
2helpful
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
OK? shows in the display.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
2answers
Auto MCACC Screen Appearing
It would appear the unit thinks your McAAC microphone is inserted. Is it?
Automatically setting up for surround
sound (Auto MCACC)
The Auto MCACC Setup measures the acoustic characteristics of your listening area, taking into account
ambient noise, speaker size and distance, and tests for both channel delay and channel level. After you have set
up the microphone provided with your system, the receiver uses the information from a series of test tones
to optimize the speaker settings and equalization for your particular room.
Make sure you do this before moving on to Playing a source on page 11.
Important
• Make sure the microphone and speakers are not moved during the Auto MCACC Setup.
• Using the Auto MCACC Setup will overwrite any existing settings for the MCACC preset you select.
• Before using the Auto MCACC Setup, the headphones should be disconnected and the iPod
USB, XM or SIRIUS Radio function should not be selected as an input source.
1 Switch on the receiver and your TV.
2 Connect the microphone to the MCACC SETUP MIC
jack on the front panel.
Place the microphone so that it's about ear level at your normal listening position (use a tripod if possible). Make
sure there are no obstacles between the speakers and the microphone.
The Auto MCACC display appears once the microphone is connected.1
Note
1 • You can't use the System Setup menu in either the main or sub zone when the iPod USB, XM or SIRIUS Radio input source is selected. When you set ZONE 2 to ON (page 61), you can't use the System Setup menu.
• If you cancel the Auto MCACC Setup, or leave an error message
etc.
It's all in the manual.
Some background on the process...
http://www.pioneer.eu/eur/products/42/98/tech/AVAmplifierReceiver/AF_MCACC.html
12helpful
5answers
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
32helpful
3answers
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
4 Press SOUND RETRIEVER to confirm.
OK
Dial norm +4 on Pioneer vsx-ax4avi-s? Understand is an auto feature but annoying, controls volume level. can it be switched off/
here is a link to your manual:
http://www.pioneer.co.uk/uk/products/archive/VSX-AX4AVi-S/media.html
looks to be an auto calibration the mcacc turned on during the testing and setup phase. you could always put the mcacc in manual mode and go through the settins yourself. Just be aware that the setting you are talking about controls the level of you dialog channel and lowing might cause you to have less ability to hear low dialog.
Cheers!
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
