Cleaned carb on echo headge trimmer how do i redo settings
It will depend on what type of carburetor you have. You can go to this website and enter your model and it should give you the correct settings. If you cannot find the info, start with each about 1 1/2 turns out and go from there. A little hit and miss and you will figure the correct setting. When setting the high speed, you want to hold the throttle wide open and slowly adjust the screw. It will suddenly start to run very smoothly, and that's a good setting for the high speed.
http://www.echo-usa.com/faqs.asp
