20 Most Recent ECHO, Inc. PB-251C Handheld Blower Questions & Answers
6answers
Echo gt 200r trimmer will bog down once the
Take a look on amazon for parts: Amazon com Echo gt 200r parts I hope you can find what you need. Regards Micky
4/29/2022 10:33:19 PM • ECHO, Inc.... • Answered on Apr 29, 2022
Echo blower wont fire
you sheared the flywheel key... If it's a PB250 251 or something along those lines you are going to need a new carb and flywheel. Take it to the dealer and see if they can fix in under warranty... Why the carb you say, it leaked causing the flywheel to come loose. If it's not under warranty then do not repair, you can buy a new one for about $160 USD
8/16/2021 4:03:15 PM • ECHO, Inc.... • Answered on Aug 16, 2021
My Echo PB-251 will not
have the carby overhauled the pump diaphragm and the float diaphragm rot with the fuel ( especially if e-mix is used ) check that the primer bulb is soft and not cracked
10/25/2017 9:57:45 AM • ECHO, Inc.... • Answered on Oct 25, 2017
Went to start bp251 blower
Take plug out turn blower to where plug hole is down pull starter cord many times until all fuel is out. Clean plug, install, try starting without priming or choking. If no start try priming just until you get fuel to engine. Try starting again. If this works when storing blower leave fuel cap slightly loose in very hot weather until you want to start.
8/9/2017 8:02:47 PM • ECHO, Inc.... • Answered on Aug 09, 2017
How hi is a 'basket ball hoop hight
Ten foot.
10/22/2016 3:35:38 AM • ECHO, Inc.... • Answered on Oct 22, 2016
My Echo PB-251 leaks gas
well 1st thing with the amount of alcohol that's in gas now days it's no longer a safe/good idea to store even for short time power tools with fuel in them , second are u sure its coming from exhaust or maybe near there ? reason I ask is that maybe there's a fuel hose that's leaking and it runs out near there , this needs attention as fuel could continue to leak out when tool is in operation as well , leaking hoses are a very common problem in todays power tools , from a 600 hundred dollar huskavarnia to a 40 dollar echo none of them make fuel hose they all buy them (probably from same place)
3/29/2016 3:42:29 PM • ECHO, Inc.... • Answered on Mar 29, 2016
2answers
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
5/19/2015 1:48:50 PM • ECHO, Inc.... • Answered on May 19, 2015
2answers
Weed eater is locked up. can not pull cord at all.
Try taking the cover off around the pull if you can. Likely the cord is not free to spin, or there is a rub on the fly wheel stopping it from moving.
3/13/2015 9:01:20 PM • ECHO, Inc.... • Answered on Mar 13, 2015
3answers
I have an echo leaf blower. I just replaced the fuel line and fuel filter. It runs fine until I point it at the ground. Then it stalls and dies. If I start it and point it towards the sky it runs grea
I would get a carb kit (they're cheap) and completely clean the carb. Also, check out the gas tank vent. It's definitely a fuel issue.
3/10/2015 2:20:30 PM • ECHO, Inc.... • Answered on Mar 10, 2015
How to install a throttle cable on an ECHO PB-251 blower
throttle cable ??? should actually have a throttle rod that goes to a very short piece of cable. and this cable only goes from the carb to the throttle rod. the cable is actually easy to replace. it's only 3 inches long. the throttle rod or trigger requires removal of one side of the handle.
3/6/2015 3:50:20 AM • ECHO, Inc.... • Answered on Mar 06, 2015
2answers
Echo leaf blower has gas coming out of the exhaust
My ECHO dealer told me that my PB-251 was not worth repairing because it was 2 years old an to buy a new one... It will not be another Echo. So much for the 5 year war. I'm not very happy........
3/6/2015 3:46:09 AM • ECHO, Inc.... • Answered on Mar 06, 2015
Echo wont stay on
the most common problem i have seen with these small engines is wasp nests in the exhaust outlet
2/13/2015 10:50:36 PM • ECHO, Inc.... • Answered on Feb 13, 2015
2answers
I have an Echo PB251 Handheld Leaf Blower that I just installed a new carburetor on and it still won't start - WHY?
You might need to check the compression on the cylinder.
1/5/2015 9:17:36 PM • ECHO, Inc.... • Answered on Jan 05, 2015
What do I use to clean the exhaust intake on my Echo PB2100?
With the unit cold you can spray some carb cleaner into the intake and the exhaust screen to remove fouling deposits. Be safe and good luck
11/28/2014 3:17:57 PM • ECHO, Inc.... • Answered on Nov 28, 2014
Pb 2105
50:1
9/22/2014 3:59:31 AM • ECHO, Inc.... • Answered on Sep 22, 2014
Where is the coil located on a echo handheld pb255 gas blower?echo
just follow the plug wire right to usally under cylinder or near recoil houseing
9/2/2014 3:41:20 PM • ECHO, Inc.... • Answered on Sep 02, 2014
Echo troubleshooting
check to see if the wire between the trigger and the carby has not come off.
8/10/2014 3:24:07 AM • ECHO, Inc.... • Answered on Aug 10, 2014
Where is the flywheel located on an Echo PB251 gas leaf blower?
Before you go through the trouble of dismantling the blower to get to the flywheel you should perform a compression test. 140 psi is ideal. Less than 100 its probably not worth repairing. Less than 90 it shouldn't run.
7/28/2014 12:09:12 AM • ECHO, Inc.... • Answered on Jul 28, 2014
I purchased an Echo PB-251 leaf blower on ebay from a crook who said it only needed a carb cleaning - quite a few carb parts were missing. After replacing the missing parts, cleaned the carb and exha
It is very possible that the exhaust ports are plugged with carbon. If so, do not use a metal object to clean them, rather a brass or wooden dowel. Is the cylinder on tight? See if it is loose (4 screws hold it tight, do not over tighten). Flywheel key in place and not sheared?
7/20/2014 10:26:05 AM • ECHO, Inc.... • Answered on Jul 20, 2014
ECHO, Inc. PB-251C Handheld Blower Logo
198 questions posted
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
View Most Popular
Echo Garden
  • Echo Garden
Most Popular Question
echo gt 200r trimmer will bog down once
  • Garden
