Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
I discovered using a Thumb Tac was a suitible tool for this task.
SOURCE: how to remove links on invicta russian diver watch
Hi Pate the only thing i can advice you is go to a service center near to your place.All watch technician like me have the knowledge to remove the links with no impaired damage or scratch.We know how to detach the links.So if want to know more of your watch i will give you a site that can help you and ask more information about your watch. www.invictawatch.com
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have
arrows inside bracelet.Arrows are pointing the way the pins must come
out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
