Can you wire up a kenwood CD stacker to a honda stereo? We have a 1996 honda legend that came with just a honda brand stereo we have been given a Kenwood CD stacker so want to know if you can if not then which CD stacker is compatible?
I seriously doubt it, though there could be a problem with the antenna. See if theres a power antenna fuse. If it's embedded in the glass, look for a broken clip at the window or loose wiring.
cant see any original factory 6 cd stackers for sale in Australia anywhere better to upgrade to a better after market unit
these CD stacker units do wear out /dry solder /corrosion /diodes
is this the factory cd stacker player that came with that model ..is this unit in the boot only thing is check all the currents volts to the stacker make sure the stacker has an individual earth wire
Have you removed the "trim panel" that surrounds the stereo? If not, do so 1st, then there "should" be 4 screws that hold the stereo in place, remove those 4 screws then pull the stereo forward (towards you), next disconnect the "bulk wire harness" connected @ the rear of the stereo along w/ the "antenna" cable and you should be home free from there. let me know if this helps.
1996 Honda Accord Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/White
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
if you have run the cable thru the car to get it up thru the dash you need to drop the glove box down. just take out the screws that hold the inside of the glove and drop it down. remove the radio and thru the hole use a draw wire to pass thru to the corner where you have dropped down the glove box.use the draw wire and tape the thicker
cd cable to it and pull it thru to the radio front. refit all removed parts. hope this helps.
If you still have the factory keyless entry for your civic, the stock radio is still located within the car. Most likely it is located behind the center console. There is a button on the radio between the AM/FM and CD buttons. Turn the ignition on without starting the car, hold the button down and push any button on the fob to program the fob.
