Here's a solution: STOP BUYING GARMIN !! I purchased TWO c330's. Both of their batteries have failed. BOTH units take over two minutes to locate satellites (regardless of my location). BOTH units take a LONG time to switch from Daylight to Night screen mode. I bought Garmin's because I THOUGHT I would be getting quality merchandise. Was I ever wrong ! Guess next time I'll try Tom-Tom (already had Magellan's ---reliable but tended to get lost easily !)
Dave
Spring Hill, FL
Now that 7 years have passed, I have learned that the problem with thebatteries seemed to be limited to the "Street Pilot" Gamin's. I have had a few Nuvi's since my first review and they have not had any battery problems. I did have one that sometimes could not finds its location, but usually worked OK. I did try a Tom-Tom (total junk).
Remove the front silver colored plastic frame from the front. you can use your finger nail to pry it open (underneath the upper side). You will then see 4 screws which will open the front cover. the battery (round cylinger) is under the metalic bent plate (2 more shiny screws) between the speakers.
hope this helps.
good luck.
I need to know where the batteries go
