Electric Razor E200s Seated  Scooter-red/silver Logo
Posted on Oct 18, 2009
Can i turn e200s electric scooter on at switch when charging
Anonymous
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Aug 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
39672
Points
87
No do not turn on the scooter while charging. When the scooter is on it is consuming power. So if you were to have the scooter on while charging, not only would it take longer for it to charge but it would cause problem for the battery. Because you want it to discharge while charging.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4175
Points
I like that scooter
Razor e200 power scooter goes very slow
the battery is probably dying out and you need a new one, or need to charge
Bella scooter light says charged but nothing happens when turn throttle
check the batteries with a multimeteer and make sure they are putting out at least 24 volts
3helpful
2answers
I have a razor e200. Nice physical condition. Garbage picked. Light on throttle lights up next to the 24V label. No power when throttle is open. No engine noise. power switch is on. reset button is...
Charge the batteries. If still no power than replace the batteries because they are dead. The batteries in the scooter need to be kept charged. If the scooter has not been charge in two weeks to a month and over. They are probably dead and need replacing. Find replacements at razor.com
2answers
What do you do when ur razor e200 electric scooter stops working?
First try charging the battery, if that doesn't work then replace the batteries with replacements from razor.com. This should solve your problem
E20 razor rocket electric scooter will not charge and someone said you need to insert a fuse but it doesnt tell you were or how. i have only purchased this as a christmas present for my daughter but it...
If it is a fuse problem then try looking for a fuse box in the controller or charger. If not then take it back, unless stated in the manual that you need to enter a fuse before it will charge, the scooter should charge right out the box.
Another thing you might want to try is to turn the scooter off before charging.
6helpful
3answers
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
