You said your iMac G4 "has PowerPc", do you mean it has a processor upgrade card, or is it original equipment? To run 10.4, A.K.A. 'Tiger', your iMac G4 needs: built-in FireWire, at least 256 MB of RAM, a drive that can read DVD's, 3 GB or more of open disk space (4 GB if you want to install X-Code Developer tools). Does your iMac meets these minimums?You said your iMac G4 "has PowerPc", do you mean it has a processor upgrade card, or is it original equipment? To run 10.4, A.K.A. 'Tiger', your iMac G4 needs: built-in FireWire, at least 256 MB of RAM, a drive that can read DVD's, 3 GB or more of open disk space (4 GB if you want to install X-Code Developer tools). Does your iMac meets these minimums?
not really sure what you want? but here goes there is no way to upgrade the G4 to an intel by replacing its components. You need to buy an intel mac, do you want a specific machine recommendation if so buy either an intel imac or mac mini (if you buy a mac mini you will need to purchase a display as well)not really sure what you want? but here goes there is no way to upgrade the G4 to an intel by replacing its components. You need to buy an intel mac, do you want a specific machine recommendation if so buy either an intel imac or mac mini (if you buy a mac mini you will need to purchase a display as well)
You can't post conmments that contain an email address.
Leopard requirements/10.5.x...
* Mac computer with an Intel, PowerPC G5, or PowerPC G4 (867MHz or faster) processor
minimum system requirements
* 512MB of memory (I say 1.5GB for PPC at least, 2-3GB minimum for IntelMacs)
* DVD drive for installation
* 9GB of available disk space (I say 30GB at least)
Classic/OS9 Apps no longer supported.
The folder and do not enter sign means that the drive is not compatible. I'm going to guess that the drive came out of an intel Mac that had leopard loaded on it. This is not going to work with a PowerPC Mac. Do a clean install of leopard and you should be fine. I believe g4's go up to 10.5 and g5's go up to 10.5.8.
Unfortunately there is no way to make that game run on your mac. Your mac uses the older powerPC architecture (all G3, G4 and G5 macintosh machines use this architecture) but the game requires that you have a mac using the newer intel architecture.
I found the details of the system requirements here: http://www.buzz99.com/1167/nancy-drew-trail-of-the-twister-system-requirements/
Intel and PowerPC processors are very different in how they work (Intel chips are CISC chips and powerPC chips are RISC chips), which is why there is no way around it. This is also the reason why apple dropped support for the powerPC architecture in mac OS 10.6 upwards.
Without meaning to sound harsh, it may be time to consider an upgrade - macs are very expensive but the intel macbooks are leaps and bounds faster than the powerPC range :)
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry. ken
If you read the system requirements of Sims 3, it says that you need at least an Intel Core Duo processor, which the iMac G4 does not have. The iMac G4 has a PowerPC processor.
Unfortunately, there is no practical way to upgrade from an older PowerPC machine to an Intel machine. In addition to the CPU chip itself needing to change, there are many aspects of the system that are not compatible. The only practical way to do this is to buy a new Intel CoreDuo machine.
The good news is that if and when you buy a new machine, you can easily transfer all of your software and settings via the OSX installer.
Good luck with your upgrade.
to mount somthing in a mac is basicly cutting it on for use. ' For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
the Samson C01U picks up the noises running inside the computer, or laptop whichever you have. You can't change that. But if you want to get rid of it. I use Cool Edit Pro. There's this effect we have for Noise Reduction. I won't go further on unless you have this program, or something similar. But basically it takes out any unwanted static
Mac help is built into the operating system on your computer. There really aren't any paper manuals for them. Here is a link to Apple's web site that should get you started: http://www.apple.com/support/imac/g4/
