Watches Logo
Anonymous Posted on Oct 17, 2009
The folding deployment clasp on the bracelet/strap for my Tag 1000 series ladies watch has broken. Might a replacement clasp from any of the current tag models fit?
Anonymous
Level 2:
Sniper:
  • Expert 61 Answers
  • Posted on Oct 17, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
61
Questions
0
Helped
70737
Points
170
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Testimonial: "Thanks - I'll try that!"
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
696
Points
How i can i solve the number series
Does any sell just the watch straps some of mine wore out
Depending on what brand you are seeking, I stock a great many.
The Rolex oyster bracelet being very popular and one of my best sellers.
I can supply bracelets for any watch. If the factory made it, I can get it.
Email me [email protected]
Have added some pics of the Rolex bracelets
tip
Watch glossary: C (part1)
CABOCHON
Any kind of precious stone, such as sapphire, ruby or emerald, uncut and only polished, generally of a half-spherical shape, mainly used as an ornament of the winding crown or certain elements of the case.
CALENDAR, ANNUAL
An intermediate complication between a simple calendar and a perpetual calendar. This feature displays all the months with 30 or 31 days correctly, but needs a manual correction at the end of February. Generally, date, day of the week and month, or only day and month are displayed on the dial.
CALENDAR, FULL
Displaying date, day of the week and month on the dial, but needing a manual correction at the end of a month with less than 31 days. It is often combined with the moonphase.
CALENDAR, PERPETUAL
This is the most complex horology complication related to the calendar feature, as it indicates the date, day, month and leap year and does not need manual corrections until the year 2100 (when the leap year will be ignored).
CALIBER
Originally it indicated only the size of a movement, but now this indication defines a specific movement type and shape (e.g. round caliber) and combines it with the constructor's name and identification number. Therefore the caliber identifies the movement.
CANNON
An element in the shape of a hollow cylinder, sometimes also called pipe or bush, for instance the pipe of the hour wheel bearing the hour hand.
CARAT (KARAT)
Unit of gold fineness (and gemstone weight). Pure gold is 24k. 18k gold is 75% pure.
CAROUSEL
Device similar to the tourbillon, but with the carriage not driven by the fourth wheel, but by the third wheel.
CARRIAGE or TOURBILLON CARRIAGE
Rotating frame of a tourbillon device, carrying the balance and escapement. This structural element is essential for a perfect balance of the whole system and its stability, in spite of its reduced weight. As today's tourbillon carriages make a rotation per minute, errors of rate in the vertical position are eliminated. Because of the widespread use of transparent dials, carriages became elements of aesthetic attractiveness.
CASE
Container housing and protecting the movement, usually made up of three parts: middle, bezel, and back.
CENTER SECOND HAND, see sweep second hand.
CENTER-WHEEL
The minute wheel in a going-train.
CHAMPLEVé
Hand-made treatment of the dial or case surface. The pattern is obtained by hollowing a metal sheet with a graver and subsequently filling the hollows with enamel.
CHAPTER-RING
Hour-circle, i.e. the hour numerals arranged on a dial.
CHIME
Striking-work equipped with a set of bells that may be capable of playing a complete melody. A watch provided with such a feature is called chiming watch.
CHRONOGRAPH
A watch that includes a built-in stopwatch function, i.e. a timer that can be started and stopped to time an event. There are many variations of the chronograph.
CHRONOMETER
A high-precision watch. According to the Swiss law, a manufacture may put the word "chronometer" on a model only after each individual piece has passed a series of tests and obtained a running bulletin and a chronometer certificate by an acknowledged Swiss control authority, such as the COSC.
CIRCULAR GRAINING
Superficial decoration applied to bridges, rotors and pillar-plates in the shape of numerous slightly superposed small grains, obtained by using a plain cutter and abrasives. Also called Pearlage or Pearling.
CLASP
The attachment used to connect the two ends of the watch bracelet or strap around the wrist.
- Deployment Buckle - A three-folding enclosure, which secures the two ends of the bracelet and allows enough room for placing the watch on the wrist when fully deployed. When closed, the buckle covers the two-piece folding mechanism
- Hook Lock - Two separate units each fitting on either end of the bracelet which allows the watch to be laid out. One end of the closure hooks onto the other to secure the two ends of the bracelet.
- Jeweler's Clasp - A closure that is generally used on better bracelets. Also allows it to lie flat.
- Sliding Clasp - Also a hook type method but allows for easy sizing of the bracelet by sliding up.
- Twist Lock - A closure similar to Jeweler's Clasp used on ladies jewelry bracelets.
CLOISONNé
A kind of enamel work - mainly used for the decoration of dials - in which the outlines of the drawing are formed by thin metal wires. The colored enamel fills the hollows formed in this way. After oven firing, the surface is smoothed until the gold threads appear again.
CLOUS DE PARIS
Decoration of metal parts characterized by numerous small pyramids.
on Jan 11, 2010 • Watches
I accidentally stepped on my Tag Heuer TWWK1120.BB0314 bracelet now the clasp doesn't click and lock. Do I need to replace the whole bracelet or just the clasp.
Has it broken, or just been bent out of shape??? If it is just bent you could possibly take it to a TAG repairer or a watch maker to get it adjusted
2helpful
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
4helpful
Hello, I have received a just bling womans watch as a gift and can't figure out how to put the wrist ********. Just bling/ JB 6210 serial #17861854
Your watch has double folding clasp and it is opening by pulling bracelet exactly in the middle of clasp. Some clasps are very stiff, so, use a bit of force to open it. Here is the link where you can see how the opened clasp looks:
http://www.amazon.com/Just-Bling-Ladies-JB-6210-Diamond/dp/B002JPK310
How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Taking links out of a tag watch
TAG Link watches has very distinctive bracelets, but there is the price to pay for it- as they do wear out it's almost impossible to repair and costly replacement is needed.
In your case: open the clasp first and check if the bracelet end links has holes on sides. If yes, then find which end of the pin is split or have groove in it. This end Must come out first! Use small hammer and hardened steel pin to drive bracelet pins out.
When assembling bracelet back together, note that the pins MUST go back exactly the same way as they came out (blunt end first in and split end last).
Good luck
Arthur
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Top Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Watch Expert? Answer questions, earn points and help others
