Fossil ES9439 Wrist Watch Logo
Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a new glass for my fossil watch fossil blue CH2435
Anonymous
Level 2:
Sniper:
  • Expert 61 Answers
  • Posted on Oct 17, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
61
Questions
0
Helped
70739
Points
170
This is will take a jeweler or watchmaker to fit with a new crystal.
1st take this watch to the point of purchase and see if they can assist you, sometimes they will surprise you and depending upon the age of the watch may replace.
2nd beyond that usually only independant jewelers will work with fossils, almost all chains will not allow their employees to even change batteries in a Fossil (they are easy to break).
  • Anonymous Jan 28, 2012
    fall watches crystals (the glass or plastic "window" on the front) your jeweler has to either order one from a watch parts wholesaler and put it in for you or send it to a watch repair place to do it
2answers
REQUIRE REPLACEMENT GLASS FOR FOSSIL STARCK O RING PH 1085 901008 WATCH.
same problem. If this is a design defect I would hope they would replace it free
The hands have come off my fossil FS3087 wrist watch. I would like to know how to take off the glass in order to fix it myself. Thank you
mcdevito75 here, In most cases the glass (crystal) come off or out thru the back of the watch which means you"ll have to remove the quartz mechanism, and that means removeing the stem, thse quartz stems are very prone to breaking while being removed form the quatrz mechanism and the cost of a repair may be more expensive then a whole new watch, shop around get a price from a small watch repair shop on repair verses a new Fossil watch.
If need new glass front??The face is scratched and needs replacing,where do I go??? Fossil JR8096,mans wrist watch
you can go to fossil.com and they have a repair site for like thirty bucks you can pay to have any parts repaired guess thats what i will have to do to get a replacement band for my own.
The glass front came out of my Chronograph Black Dial fossil watc
Go to a watchmaker/technician. They will have a press that they can use to apply even pressure putting the crystal back in place. Be careful that you do not lose the teflon seal sitting where the crystal goes and do not let any dirt or contaminants get to the face of the watch. Be sure you ask them to pressure test it to be sure it is water resistant.
1helpful
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Glass foggy or has film on inside
The film is moisture, you may have to remove the back and let if evaporate. You need new seals as it is your sweat that is causing it.
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
