D-Link DSL-G604T Wireless Router Logo
Allan Clarke Posted on Oct 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have D-Link G604T router/modem and want to connect my TP-Link TL-WA501G Access Point. Problem is router is not automatically assigning an IP address to the TL-WA501G Access Point. The D-Link gateway is 10.1.1.1 whereas the TP-Link AP gateway is 192.168.1.1 how do I get into the menu of the TL-WA501G?
abdul latheef
Level 2:
  • Expert 145 Answers
  • Posted on Oct 17, 2009
abdul latheef
Expert
Level 2:
Answers
145
Questions
0
Helped
38308
Points
447
2answers
How to set up my router with modem?
Connect the router to the modem with an ethernet cable, CAT 5, 6 or 7. Try amazon.
2answers
EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Network operater for WiFi router lumia 510
https://www.youtube.com/watch?v=ptjVQXmfLKA
Wi Fi needs a router with Wi Fi that is transmitting its identity with an ssid http://www.webopedia.com/TERM/S/SSID.html
Where are you trying to connect lumia 510 to. Is it at home do you have an existing internet router with several ethernet ports on the back of it. If yes then you need a Wi Fi access point or Router.
https://en.wikipedia.org/wiki/Wireless_access_point
http://www.4cabling.com.au/tp-link-wireless-54m-access-point-tl-wa501g-14622.html#.VayN1fk_yrY
I have a TP LINK router, it transmit signal properly. the problem is when the 3G USB internet modem is fixed into it, it does not send internet signal so the laptop shows TP Link signal: excellent, but no...
To solve your problem:
go here
http://www.tp-link.com/us/article/?faqid=92
Basically what you have done is plugged it in but did not set up the router on a static or dynamic IP address.
Once you have established the IP address of the router and it is recognized by your ISP device (DSL, Cable, Satellite modem ....etc etc.) then you have to decide which device will be the DNS server and assign IP address to all the wireless devices that connect to it.
Lots of things can be wrong. You need to follow the steps on the set up link i gave you properly and in the correct order
No light only power light is on...
First, did you pay the bill? Unplug the IPS modem, remove battery, if applicable, unplug TP Link, shut down computer. Ckeck ALL cables reseat, Replace battery, plug in ISP modem, allow it to selftest, plug in TP Link, allow it to selftest, Reboot computer. If you connect ISP Modem directly to PC and it doesn't ID your IP address use this: http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/ To assist you. If this doesn't work contact your ISP provider . Try another Wireless Access Point. My ISP, Xfinity, drops from time to time , for no appearent reason, due to a number of outside difficulties.
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
I have access point TL-WA500G and I can`t open my admin i do reset`t but stell can`t open my admin .
The Issue you are having is that you might be typing in the wrong IP address for the Access Point.
Follow these Steps Below and this should fix your problem.
Step1:Open your web browser.
Step2:Type in IP address http://192.168.1.254 in the address field of web browser and press Enter.
Step3:Enter admin for the User Name and Password (both in lower case letters).
Step4:Then click OK or press Enter.
Go to This web Address to get a copy of the manual for your device in PDF Form.
http://www.tp-link.com/english/soft/TL-WA500G_User_Guide_201003.pdf
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
