I try and turn on my tv the blue light comes on like its trying to turn on and then it clicks and the blue light starts flashing along with 2 red temp and amp lights below the blue power light
Either a relay or power supply or high voltage transformer is bad. You can test any of these with an ohmmeter and a voltmeter or better yet a multi-meter. Then if low or no resistance, it is bad.
JustAnswerhttps://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ... 1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
https://www.askmefast.com > My_nordmende_tv_mo...
Normende tv red light wont come on Nordmende tv blue light flashing Nordmende ... said: nope. will turn on and work fine until the screen dims, goes black.
Most likely it's the power supply board that went out. (part of it still works is why you get the blue LED when you plug it in.)
If you decide to try to fix it yourself, BE CAREFUL! The power supply board has capacitors that can hold high voltages for many hours after the TV's been unplugged.The equivalent of sticking your finger in a light socket.
You'll need the part number off the power supply to get a replacement.
Tries the tv unplug,replug the tv back an hour later,let the tv reset itself back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c plug into this board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
