Porter Cable 12v 3/8" Cordless Drill/driver Kit Logo
Posted on Oct 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The electronic brake does not work
The electronic brake on my Porter Cable 12v driver/drill does not work. Is there a part to replace?
Anonymous
Level 3:
  • Master 2,176 Answers
  • Posted on Oct 14, 2009
Anonymous
Master
Level 3:
Answers
2176
Questions
6
Helped
1311934
Points
5445
Should be the switch, give me the model number and I will find a part number for you.
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
1helpful
Porter-Cable battery charger model #8605
go to www.dewaltservicenet.com and enter the model number of your drill. It will get you to the parts breakdown and will tell you if there is a charger available from the factory. Or call 1-800-433-9258 1-800-4DEWALT. stanley black and decker owns all of them so yes that's the right place!
I have a ns100a porter cable narrow crown stapler. The driver will not retract, so it will not shoot staples. what can be the problem and how can I fix it? Thanks Pam
Usually when the driver is slightly bent, it will not retract. Easy to check. Remove the head and pull out the cylinder and driver together. Adjust the driver or replace as needed.
Can I get the schematic drawing for a Porter Cable Drill/Driver Model 826 1/2"?
There is a good parts breakdown for this drill on www.ereplacementparts.com. They are also a fairly good place to get replacement parts but most of the parts for this drill are discontinued.
Dead power tool battery
You can learn how to bring your Nicad cordless power tool batteries back to life with Battery Resurrection.
A simple procedure will enable your Nicad cordless power tool batteries to again charge in your battery charger and give their full power potential. Works for ALL Nicad batteries including Dewalt, Makita, Craftsman, Skil, Ryobi, Milwaukee, Firestorm, Versapak, Black & &Decker,Coleman,Bosch,Porter Cable, Fein,Hitachi and more.
Battery Resurrection is a registered trademark of Unique Dynamics Inc. Check it out below:
http://www.batteryresurrection.com/
Testimonials from hundreds of users: http://dewalt-battery.uniquedynamics.com
2helpful
Need owners manual for Porter Cable FN250C 16 Ga. nailer
Here's a link for PDF file download of your manual.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/N027636,DA250C.pdf
Porter cable 3/8 chuck model 621. need to replace and cant find it
if you are talking about the J621 3/8 Professional drill the chuck kit number is 692074 and it lists for 43.30. You can but that from Dewaltservicenet.com or if you need more assistance let me know.
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Top Porter Cable Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
