Sony Ericsson P990i Cellular Phone Logo
Posted on Oct 10, 2009
Phone will not turn on
Yes, i am having the same problem. I have recently put on a new theme then it comes up "APPLICATION CLOSED" so i restart my phone. Now my phone wont load up fully. HELP !!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 30, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
124
Points
I am having the same problem. I have recently put on a new theme then it comes up "APPLICATION CLOSED" so i restart my phone. Now my phone wont load up fully. HELP !!!
5helpful
How can i install themes for my lg Kp500 cookie because i want to change it
There are 2 location were you can store the themes on your phone, either on phone memory or in memory card.
If the theme application comes from the computer, you need to transfer it on your memory card by using a multi media card reader, you can make a folder were you can place the themes or just put in on the root directory of the memory card,now from your phone, locate the file manager by going to your phone settings. just run it and follow some instruction,then after the process is done, go to theme settings and run the theme application you download.
If the theme application directly download on your phone via bluetooth or GPRS, just locate the phone memory on the file manager and do the same way.
You can download themes from this free site : KP500 THEMES
Hoping this method helps you.Good Day..
1helpful
How can i put a themes in my nokia n95 8gb?
Hi
Before installing any software go to
Menu> App.Manager> Options> Settings> Software Installation
In Software Installation make it ALL. This change is important, otherwise you will get an Error message Certificate Error. Contact the application supplier while installing most freeware
Also, if you see that some old themes are giving the Expired Certificate error, simply change the date of your phone to year either 2005 or 2006 or 2007 (check all as each theme has a different expiry) before installing the theme. After installation you can change back to today's date.
Now, here is the way to install themes and other applications in your Nokia . I use the USB Cable to do the installations.
1. First install the Nokia PC Suite software on your computer from the CD which you recieved with your Nokia
2. After Nokia PC Suite is installed in your PC, connect the Nokia to the PC with the USB cable which was provided in the box.
3. When the USB cable is connected, Nokia PC Suite will recognise that a phone is connected. You will then see an option on your phone?s screen asking if you want to connect via PC Suite or Data Transfer. Choose PC Suite.
4. Now, simply download the .sis or .java files (themes & applications) to your computer and Right Click on it with your mouse. You will see an option saying Install With Nokia Application Installer
5. Click Yes on the PC, and then Yes & Continue on the Phone when you see the prompts.
6. The phone will then ask you if you want to Install the Theme or Application in the Phone Memory or Memory Card.
I strongly recommend Installing themes in the Phone Memory! This helps in avoiding complications later on when Uninstalling.
When I first bought the Nokia N95, I made a mistake which a lot of new S60 3rd Edition users make, that is, I installed the Themes in the Memory Card instead of the Phone Memory. This was a huge mistake!
There is a bug in the Operating System of all S60 3rd Edition phones, due to which, if the theme is installed in the Memory Card, it cannot be deleted or removed, as it then does not show up in the Application Manager.
Ever since that mistake, I have made sure to always install themes and softwares in the Phone Memory, instead of the memory card. Yes, it eats up space on the phone, but it's worth it, as then it is easily removed as well.
And that's it, the theme or application is now installed!
Thanks for using Fixya.
Turn on problem
sorry bout that but first go get it looked at
Dec 01, 2009 • Cell Phones
1helpful
I am having the same problem. I have recently put on a new theme then it comes up ''APPLICATION CLOSED'' so i restart my phone. Now my phone wont load up fully. HELP !!!
This happens often on Blackberry devices, when a corrupt theme is loaded.. On BB's I have them WIPE the memory of the device and start over loading the email accounts etc. Not sure what model of phone you have, but it's probably the same type of deal. Go back to factory settings.. and don't load that theme again.
My SE p990i wont on
the theme was not works properly delete the theme imediately
1helpful
How to re intall software in Sony ericsson p990i
Hi Sahil,
Plase check with the following. May it will help you resolving the issue you are facing.
http://my-symbian.com/uiq3/faq/showquestion.php?fldAuto=4&faq=2
Thanks,
Ram
5helpful
2answers
N73 memory full
u may press, *#7370# then it will show the lock code that is 12345 then ur phone will restart and the problem will definetly solve.
1helpful
2answers
Reset blackberry 8700
same here. downloaded theme, reset in little box, turns on and off.
Sony ericsson p990i wont turn on
also have a P990i and ive installed a new theme and used that theme, then i tried to enter control panel several times it does not let me and shows me a message like "Application closed/Kern......./Reason.........."!! So i turned off the phone and restarted it but it only shows sony ericsson logo and it is not going further.
2answers
P990i cant be turned on :( !!
thats the only way to re install the software..i did that ..now im ok.lost all my data but its worth it...
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
