KitchenAid KGSA906P F1 E1 error code...oven has previously cut off unexpectedly, have also been unable to shut off oven without inputting a stop time...Seems like the end of a long series of problems
Re: f1 e1 error code...oven has previously cut off
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect. Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question #$#$
F1 - E0
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
F1 - E1
EEPROM checksum error
F1 - E2
UL A/D error(s)
F1 - E4
Model ID error
F1 - E5
Calibration shifted
F1 - E6
Latch signal mismatch error
F1 - E9
Stack overflow
F1 - E3
Wiring harness cavity size does not match previously stored value
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
If this is a Kitchenaid, Roper or Whirlpool range, this error indicates an EEPROM error in the control board. Ifthe F1 E1 trouble code continues after you've disconnected the power for over 30 seconds, you need to replace the electronic control board (clock). You can often find parts online with the model number of the unit. (Try partselect.com or searspartsdirect.com (if Sears sold the model).)
1. Disconnect power for at least 30 seconds. 2. Re-apply power and observe for at least one minute. 3. If code re-appears, replace control board (also called ERC or clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
