Stanton STR8-150 Turntable Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, my pitch control on the turntable doesnt hold its pitch anymore, how would i go about by fixing this please? :)
Morne Olivier
Level 2:
Guru:
  • Expert 265 Answers
  • Posted on Aug 18, 2010
Morne Olivier
Expert
Level 2:
Guru:
Answers
265
Questions
Helped
80018
Points
518
You will need to check your belt tension for wear.Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Fix speed and pitch problem sony ps-t15 turntable
The pitch control need to be cleaned. You will have the remove the bottom to do this. It will require servicing. It could also be PCB board that that controls the pitch or a bad motor.
3helpful
2answers
Recently purchased used Panasonic SL-HM42 turntable. Works, but turning a little slow on 33rpm (30-31rpms) says DC Servo System on the front. Don't see any set screws on bottom. would like to get platter...
How to tweak the playback speed on Panasonic SL-HM42 turntables
You will need:
  1. 1x small Philips screw driver
  2. 1x small flat-head screw driver
  3. An ear for correct pitch and a little bit of DIY skill!
Step 1 - Remove the wooden base plate
After ensuring that you've removed the the rubber turntable slip mat and securely docked the turntable arm, carefully flip the turntable over onto its lid to expose the wooden base plate, as per below.
Using the small Philips-head screw driver, remove the screws holding the wooden base plate in place, then gently lift the base plate off the turntable.
Step 2 - Expose the pitch adjustment screws
Once the wooden base plate is removed, you will see the speed-controller circuit board on the right-hand side.
To expose the the two speed/pitch-control screws, firstly remove the screw holding the speed-controller circuit board in place, then gently lift the circuit board up on the free side.
Step 3 - Correct the turntable playback speed and pitch
The easiest way I found to correct the playback speed was to flip the turntable carefully back into the original position, allowing the speed-controller circuit board to hang free as shown below.
Next, play a record that you know well and are able to tell when the speed/pitch is correct (assuming you have an ear for correct pitch, that is!), then at the same time using the small flat-head screwdriver, gently turn the speed adjustment screw(s) to adjust the playback speed up or down until the correct playback speed and pitch is achieved (or at least until it no longer annoys you ;).
Turning the screws clockwise (to the right) will increase the speed/pitch, and anticlockwise (to the left) will decrease the speed/pitch.
NB - Both screws allow for fine pitch control, so if the second is already at maximum speed, you can use the first screw for additional speed.
Step 4 - Reassemble the turntable again
When you're happy with the speed of your turntable, remove the record, the mat again & locking the turntable arm, replace the screw holding the speed-controller circuit in place (as per Step 2) and then finally replace the screws holding the wooden base plate, as per Step 1.
Happy listening!
2answers
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Pitch wobble 1210
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
2answers
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
1helpful
3answers
My stanton t50 turntable plays too fast even when the pitch fader is at the slowest speed
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
2helpful
2answers
Turntable will not hold pitch,speeds up or slows down.
try replacing the drive belt with brand new one and see if this improves the situation
Pitch trouble numark tt-x1
Either the pitch control is damaged, or your drive system is damaged. Unfortunately for either case, your going to need some professional assistance.
Sorry I couldn't be of much more help.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
2helpful
Pitch LED not working
LED probably burned out, or installed reverse (+/- reversed) - Or, you installed a clickless (MK3/MK5) pitch control in an MK2 turntable.
Did you do this yourself? Or did you have this professional done? If professionally, and the LED does not work, ask for your money back! This is electronics repair 101!
If you did this yourself, then more than likely you installed the LED backwards. The longer lead is the positive lead. If the LED did not burn out, you might be able to just remove it and switch it around. If it does not work, then it probably shorted (more than likely). Also make sure that none of your solder is touching. This could cause a bad short to your entire turntable. So you want to becareful.
If you need any further assistance, feel free to give our service dept a call. We are masters with the 1200s, and fix over 300 a year! 1.866.668.1596 ext 1
- TERMiNAL OPTiC
www.DJPROLAB.com
Pitch Control
use tap button your mixer to get exact bpm if you dont havr this , buy a new mixer i suggest pioneer 800
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
